BGP Route-reflector question regarding prefixes not being seen
Ravi Pande
I have the following topology for studying BGP route-reflector.
So R2 I have configured as Route-reflector and R5 is Non-client and R1,R3 are clients for R2(reflector). Next, I have configured R3 as route-reflector with R4 & R2 being its clients. I see all the loopbacks in BGP table for R2 & R3. For R1 & R5 I see all the prefixes in BGP excerpt the loopback of R4. And for R4 I see only prefixes from R2,R3,R4. I was expecting all the prefixes on all routers not sure what is wrong. Any help would be appreciated.
1) R1
   Network          Next Hop            Metric LocPrf Weight Path
*> 172.64.32.1/32   0.0.0.0                  0         32768 i
*>i172.64.32.2/32   10.0.0.13                0    100      0 i
* i172.64.32.3/32   10.0.0.10                0    100      0 i
* i172.64.32.5/32   10.0.0.6                 0    100      0 i
2) R2
*>i172.64.32.1/32   10.0.0.14                0    100      0 i
*> 172.64.32.2/32   0.0.0.0                  0         32768 i
*>i172.64.32.3/32   10.0.0.10                0    100      0 i
* i172.64.32.4/32   10.0.0.18                0    100      0 i
*>i172.64.32.5/32   10.0.0.6                 0    100      0 i
3) R3
* i172.64.32.1/32   10.0.0.14                0    100      0 i
*>i172.64.32.2/32   10.0.0.9                 0    100      0 i
*> 172.64.32.3/32   0.0.0.0                  0         32768 i
*>i172.64.32.4/32   10.0.0.18                0    100      0 i
4) R4
* i172.64.32.2/32   10.0.0.9                 0    100      0 i
*>i172.64.32.3/32   10.0.0.17                0    100      0 i
*> 172.64.32.4/32   0.0.0.0                  0         32768 i
5)R5
*>i172.64.32.2/32   10.0.0.5                 0    100      0 i
*> 172.64.32.5/32   0.0.0.0                  0         32768 i
1) R2 route-reflector
 sh run | s bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
network 172.64.32.2 mask 255.255.255.255
neighbor 10.0.0.6 remote-as 100
neighbor 10.0.0.6 next-hop-self
neighbor 10.0.0.10 remote-as 100
neighbor 10.0.0.10 route-reflector-client
neighbor 10.0.0.10 next-hop-self
neighbor 10.0.0.14 remote-as 100
neighbor 10.0.0.14 route-reflector-client
neighbor 10.0.0.14 next-hop-self
no auto-summary
2) R3 route-refelctor
do sh run | s bgp
router bgp 100
no synchronization
network 172.64.32.3 mask 255.255.255.255
neighbor 10.0.0.9 remote-as 100
neighbor 10.0.0.9 route-reflector-client
neighbor 10.0.0.9 next-hop-self
neighbor 10.0.0.18 remote-as 100
neighbor 10.0.0.18 route-reflector-client
neighbor 10.0.0.18 next-hop-self
no auto-summary
Thanks & Regards,
Ravi
Next-hop-self doesn't work by default on prefixes received from ibgp neighbors and advertised to ibgp neighbors as per RFC 4456 reccomandation
https://tools.ietf.org/html/rfc4456#section-10
In addition, when a RR reflects a route, it SHOULD NOT modify the
following path attributes: NEXT_HOP, AS_PATH, LOCAL_PREF, and MED. Their modification could potentially result in routing loops.
Next-hop-self can be forced on IOS devices by appending the "all" keyword to the command and by applying the command "ibgp policy out enforce-modifications" on IOS-XR. NX-OS needs a route-map to change the value.
If you questiona have been answered remember to mark this post as solved.
Cheers,
ADP
8 Replies 8
ADP_89
Hello Ravi,
If you take a closer look at your "show ip bgp " output you will see that some prefixes are missing the > symbol. This means that the prefixes are not the best route so they will never be forwarded/reflected to other neighbors. My guess on this is that you are missing an IGP inside you AS so the routers R1-R2-R3-R4 do not know how to reach the next hop reported by the prefixes.
There are a few ways to fix your scenario, some of them are the following:
- Run an IGP(EIGRP,OSPF,IS-IS) inside the AS and do the peerings over the loopback interface(this is a best practice in case you have redundant links between the routers). Create a new one if you just want to check/play with BGP advertisements
- On R2 apply the "neighbor X.X.X.X next-hop-self" to R1 and R3 sessions, this will announce R5 IPs inside the 100 with R2 as next-hop. In this way you do not need to include the inter-AS link in your IGP.
With this couple of changes you will see all the prefixes not only in BGP table but they also be installed into the routing-table so you can do ping/connection tests end to end.
HTH,
ADP
@ADP_89 wrote:
Hello Ravi,
Hello
That is in correct!
This  symbol > states it IS the best route not that it isn’t
* This states it is valid
Can you verify rtr4 - 5 have a valid path to each other as @ADP_89 suggested it does looks like this is due to nlri failure
show ip route | in 10.0.0
sh ip bgp update-group
Kind Regards
Paul
@paul driver wrote:
Hello
That is in correct!
You probably misread my sentence or I have written it in a non correct English form but with my "This" I was referring to the whole previous sentence, not to the symbol.
So if that symbol is missing the route is not the best.(This is what I was trying to say)
Cheers,
ADP
Hello
@ADP_89 apologies now reading it again I did misread it  - your are correct in what you were saying
and i I agree also that this failure is most probably down to those rtrs not having any valid reachability
Kind Regards
Paul
Thanks for your reply.
I have already added next-hop-self on R2 and R3.I have included R2 & R3 bgp config details. Yes, I do not have any IGP configured.
I will configure IGP and then update this post.
Hi @ADP_89 & @paul driver - Thanks for pointing that out. I configured OSPF and see that it is working fine. Could you please let me know why it was not working before.  I had configured next-hop-self on both the route reflectors so I was assuming that I do not need an IGP.
Ravi
Hello
Yes it’s down to bgp synchronisation rule stating a route shouldn’t be advertised unless there is a valid route in this case to its advertised next hop by an igp ( static- rip- ospf -eigrp)
now with synchronisation turned off this prefix is being advertised in bgp but as you don’t have a nlri ( reachability)  to the nexthop of that prefix its not being addied to the route table and just show as valid and not best route in the bgp table
Kind Regards
Paul
Cheers,
ADP
