BGP Route Selection for Single Prefix
cdobler95842
How can I manipulate incoming traffic from a specific prefix from my ISP to come through my other ISP to elevate the traffic on my 1 peer router?
I have the following setup:
ISP-A                              ISP-B
eBGP                              eBGP
Rtr-A                                Rtr-B
     |---------iBGP-------------------|
I noticed that traffic for a prefix from ISP-A 206.160.170.0/16 (streaming) is congesting my WAN interface on Rtr-A. I would like to be able to push the traffic "INBOUND" from 206.160.170./16 through ISP-B/RTR-B. I know that I can manipulate the "localpref" to do the outbound traffic, but want to do this for only this prefix, which this prefix is part of ISP-A AS.
Any suggestions?
7 Replies 7
Roman Rodichev
Level 7
Level 7
Not possible. Routing is destination based. If you want to manipulate inbound traffic then you can only manipulate traffic TO local prefix, not traffic FROM foreign prefix.
naresh.narang
enable net flow and determine which /24s of the /16 are causing highest utilization and then you should be able to receive those on different routers by using AS path using community in a routing policy that can essentially load balance your traffic.
Can you please provide a possible example with the communities? I provided further information on the bottom or below this thread.
Would this work? This would affect "OUTBOUND" and not INBOUND - Though
route-map as30263_in permit 5
match ip address prefer_as30263
set local-preference 250
ip access-list standard prefer_as30263
permit 96.0.0.0 0.255.255.255
permit 74.0.0.0 0.255.255.255
jesse.pratt
There are a few ways to solve this problem. With out knowing a bit more about your configuration i'll just throw out a few ideas.
1) you can use conditional advertisements, remove the prefix in question from ISB-A and advertise it through ISP-B. With conditional advertisements you still maintain failover capabilities as the prefix will be advertised through the other ISP in the event of a failure if configured correctly.
2) AS prepending, append the AS a few times to make the inbound routes less desirable through ISP-A.
If you need any more help just ask.
Jesse
Roman Rodichev
Level 7
Level 7
Guys, he was asking:
"I would like to be able to push the traffic "INBOUND" from 206.160.170./16 through ISP-B/RTR-B"
Neither of the above solutions achieve this. Your solutions are for controlling inbound traffic to the local prefixes, and not from foreign prefixes.
Here is some more details:
The supernet 206.160.170.0/16 is owned and advertised by AS 1239
ROUTER1#show ip ro 206.160.170.0
Routing entry for 206.160.0.0/16, supernet
  Known via "bgp 65001", distance 20, metric 0
  Tag 1239, type external
  Last update from xxx.xxx.xx.77 7w0d ago
  Routing Descriptor Blocks:
  * xxx.xxx.xx.77, from xxx.xxx.xx.77, 7w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 1239
ROUTER1#show ip bgp 206.160.170.0
BGP routing table entry for 206.160.0.0/16, version 20423274
Paths: (1 available, best #1, table Default-IP-Routing-Table)
  Advertised to update-groups:
    xxx.xxx.xx.77 from xxx.xxx.xx.77 (xxx.xxx.xxx.121)
      Origin IGP, metric 0, localpref 200, valid, external, best
      Community: 81199227 81200104 81200107
-As at this time I have the localpref set for 200 for the routes received from AS 1239 at this time on Router 1 and localpref set for 150 for the routes received from AS 30263 on Router 2.
As noted from Router 2 the following output for 206.160.170.0:
ROUTER2#show ip ro 206.160.170.0
  Known via "bgp 65001", distance 200, metric 0
  Tag 1239, type internal
  Last update from xxx.xxx.xx.77 3w0d ago
  * xxx.xxx.xx.77, from 10.255.1.1, 3w0d ago
      AS Hops 1
      Route tag 1239
ROUTER2#show ip bgp 206.160.170.0
BGP routing table entry for 206.160.0.0/16, version 116873587
Paths: (3 available, best #1, table Default-IP-Routing-Table)
  Not advertised to any peer
  1239
    xxx.xxx.xx.77 (metric 19200) from 10.255.1.1 (10.1.10.11)
      Origin IGP, metric 0, localpref 200, valid, internal, best
  30263 30263 30263 30263 30263 30263 30263 30263 30263 30263 30263 209 1239
    xxx.x.xxx.137 from xxx.x.xxx.137 (xxx.x.xxx.117)
      Origin IGP, localpref 150, valid, external
  30263 30263 30263 30263 30263 30263 30263 30263 30263 30263 30263 209 1239, (received-only)
      Origin IGP, localpref 100, valid, external
--  The issue is that the traffic from this particular prefix is high BW and I would like to move it through Router 2
- I understand if I change the local pref then this will change the direction of going out through Rtr 1 - By adding an additional line to the Route-map and filtering it to the specific prefix correct to set the pref lower through Rtr 1
-But In order to make the "incoming" prefer Router 2 - just for that 1 prefix 206.160.170.0/16 is not possible?
Thank you for your time and responses.
I'll put it simple:
changing local preference on incoming advertisements of foreign prefixes controls outbound traffic path to those foreign networks
prepending AS-PATH on outgoing advertisements of local prefixes controls inbound traffic path to your local networks
You are trying to control inbound traffic path FROM the foreign networks. This is not possible.
