BGP route selection-Multihoming
Douglas Barboza
I have a question regarding BGP route selection. I deployed a lab to simulate a multihome enviroment, after follow a couple of guides I'm confuse about BGP router selection.
Attached is the output and topology. As you can see, for a reason I'm not aware, the best path to a destination change even when the local preference of the best path is higher.
Attached is also the BGP configuration of Router 1 and Router 2 (intended to be customer routers), I dont know if I miss something.
Thanks for your comments.
Richard Burts
I do not see any attachments.
Rick
Rick
