BGP Route Selection question
Colin Higgins
Level 2
Level 2
I have a router with 2 WAN (MPLS) connections to two different IPSs.
One connection is a 3mbs MLPPP connection and the other is a 10mbs MetroEthernet connection.
Both use BGP to peer up with the ISP with private AS numbers (65001, 65002, etc)
I want the router to always prefer (use) the BGP connection through the 10mbs link, but here are my considerations:
I can't change the prefeix length for the peers. In other words, BGP 65001 is going to advertise 192.168.21.0 /24 to its peer, and BGP 65002 is going to advertise the same network with the same mask.
What is the best way to make sure the 10mbs link is always preferred? Can I do local preference?
Any advice here would be appreciated.
shehinpm1
Hi Colin,
LP will be the best option to achive,bcoz LP determines the best path for OUTBOUND traffic,using MED
we can determin the way to our AS
6 Replies 6
shehinpm1
Hi Colin,
would the
bgp default local preference ...
command under peer configuration for AS 65002 (10mbs link)
affect all networks advertised? In other words, if I have 50 subnets, the LP would be applied to all of them?
Correct ! this would change it from default value of 100
cadet alain
hI?
you could also use weight as this is a cisco router and you've got no iBGP peerings.
Regards.
Alain.
cisco_lad2004
Level 5
Level 5
Colin,
As previous posters stated, use LocPrf for outbound traffic. You should also prepend your prefixes outbound towards the less preferred peer. This will ensure traffic comes back over desirable link.
Samir
Sent from Cisco Technical Support iPad
Marwan ALshawi
Hi Collin
As suggested by other posters above you can use local preference or wight for outbound and med for inbound
But now you thinking about this site only however aim assuming you have other site that need to communicate with the advertised prefix by this router over the two ISPs
So what you need to do is to think about the outbound direction and the returning traffic as well
So if want the communications to be all over one ISP as a main path you local preference to effect this increase it in the inbound direction from the preferred peer using route map
In the outbound direction to effect how other sitesnwill com to you network use as-path prepending but you need to check withnyour ISP that they allow and accept the AS prepending and increase the as-path over the backup/less preferred ISP by adding more AS numbers to the path using rout-map and apply it toward that bgp peer in the outbound direction
Be aware that you need to use same concept in your other bgp sites with two ISP links to avoid asymmetrical routing
Use the bellow link for more detail how you can configure the above
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
If helpful rate
