BGP Routes not advertised over VRFs
Islam Nadim
Hello All,
I have this topology, where I created a backbone that should work with VRFs.
The configuration below related to the backbone routers. I'm using OSPF for the backbone and BGP on the Edge Routers.
CorePRouter:
interface Serial0/0
ip address 10.10.10.1 255.255.255.252
mpls ip
clock rate 2000000
interface Serial0/1
ip address 10.10.20.1 255.255.255.252
mpls ip
clock rate 2000000
router ospf 1
log-adjacency-changes
network 10.10.10.0 0.0.0.255 area 0
network 10.10.20.0 0.0.0.255 area 0
PERight:
ip vrf CustA
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf CustB
rd 2:2
route-target export 2:2
route-target import 2:2
interface Loopback0
description -- BGP SOURCE INTERFACE WITH PERight --
ip address 2.2.2.2 255.255.255.255
interface Serial0/0
description -- TO CorePRouter --
ip address 10.10.20.2 255.255.255.252
mpls ip
clock rate 2000000
interface Serial0/1
description -- TO CustA2 Router$$VRF CustA --
ip vrf forwarding CustA
ip address 192.168.2.1 255.255.255.252
clock rate 2000000
interface Serial0/2
description -- TO CustB2 Router$$VRF CustB --
ip vrf forwarding CustB
ip address 192.168.4.1 255.255.255.252
clock rate 2000000
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
router bgp 13879
no bgp default route-target filter
bgp log-neighbor-changes
neighbor 1.1.1.1 remote-as 13879
neighbor 1.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 1.1.1.1 activate
  no auto-summary
  no synchronization
exit-address-family
address-family ipv4 vrf CustB
  neighbor 192.168.4.2 remote-as 65003
  neighbor 192.168.4.2 activate
  no synchronization
exit-address-family
address-family ipv4 vrf CustA
  neighbor 192.168.2.2 remote-as 65001
  neighbor 192.168.2.2 activate
  no synchronization
exit-address-family
PELeft:
ip vrf CustA
rd 1:1
ip vrf CustB
rd 2:2
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Serial0/0
ip address 10.10.10.2 255.255.255.252
mpls ip
clock rate 2000000
interface Serial0/1
description -- TO CustA1 Router$$VRF CustA --
ip address 192.168.1.1 255.255.255.252
clock rate 2000000
interface Serial0/2
description -- TO CustB1 Router$$VRF CustB --
ip address 192.168.3.1 255.255.255.252
clock rate 2000000
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
router bgp 13879
neighbor 2.2.2.2 remote-as 13879
neighbor 2.2.2.2 update-source Loopback0
address-family ipv4
  neighbor 2.2.2.2 activate
  no auto-summary
  no synchronization
exit-address-family
  redistribute connected
  neighbor 192.168.3.2 remote-as 65002
  neighbor 192.168.3.2 activate
  no synchronization
exit-address-family
  neighbor 192.168.1.2 remote-as 65000
  neighbor 192.168.1.2 activate
  no synchronization
exit-address-family
The problem here, the VRF Routes are not advertised between the PEs, thus the CEs can't see each other. What am I missing here?
Jon Marshall
You need to add a VPNv4 address family configuration to both PE routers as this is used to exchange the VPN information between PE routers.
So you need to add this under your BGP configuration -
address-family vpnv4
neighbor activate
neighbor send-community both
Jon
Jon Marshall
neighbor activate
Jon
