Cisco router(s) 10/100 taking input/crc errors
david.kiernan
I am getting input and CRC errors on the WAN interface of my Cisco router.
I have tried several Cisco routers - (3) 1841's, and now a 2801.
I've  replaced all cabling.  The Internet connection (cable) has been changed  from coax (30x5 - replaced the modem 3 times as well), to fiber at  50x50.
We've worked with ISP and changed speed/duplex to different values - both auto and "locked" to matching values.
Any  possibility the 10/100 interfaces on the 1841/2801 are having issues  with the Gbe links on all sides?  The inside interface is connected to  either a Gbe switch, or to the Gbe port on the Barracuda and does not  report input errors.
Additionally, with 50x50 service, and a  single laptop connected to the inside interface of the 1841/2801, I can  only pull about 20x50.  If I bypass the Cisco and connect directly to  the ISP gear, I can pull the full bandwidth (50x50).
One last nugget of information - this interface (fa0/1) is connected to the cable ISP, but we are using BGP and a GRE tunnel to route IP space from ISP #2, which is also connected to this router with a T1 WIC.  No NAT'ing is performed on this router - ALL  IP's are public IP's.
The current configuration is:
- Cisco ME3400 fiber switch from the ISP
- copper patch cable directly to the 2801
- both devices set to auto speed/duplex
- int s0/0/0 - T1 to ISP #2
- int fa0/0 - "inside"
Leo Laohoo
Post the output to the command "sh interface ".
