BGP Routes not in Routing Table
Mantas Sti
All 3 routers are running BGP. I have only configured them with #neighbor x.x.x.x remote-as xxx command. Routers KCOM and CONNEXIN should have 1 BGP route each installed in their routing table but when I run #show ip bgp command, nothing comes up. Interfaces are configured with IP addresses and are on. I can ping KCOM and CONNEXIN routers from RTR-01.
CCNA Routing and Switching
Julio E. Moisa
BGP will advertise the routes only if you are using network command line matching the subnet mask  and if the prefixes to be advertised are into the routing table.
For example:
KCOM Router
interface loopback 0
ip address 151.1.1.1 255.255.255.255
router bgp 111
network 151.1.1.1 mask 255.255.255.255
neighbor 150.1.1.2 remote-as 500
In order to see the BGP peering status and amount of the prefixes received from a neighbor, you can use:
show ip bgp summary
and to see the BGP table:
show ip bgp
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Peter Paluch
Hi Mantas,
We need to understand more about your setup. Can you please post the complete output of the following commands from all three routers?
show ip bgp
show ip bgp summary
show run | section bgp
Thanks!
Best regards,
Peter
Hello.
I have just started learning BGP and want to really understand it. Managed to figure it out myself after spending 2 hours on this simple topology trying different commands. It's an awesome feeling to know stuff.
Thanks for your replies.
You are welcome my friend.
We learn everyday.
Julio E. Moisa
For example:
KCOM Router
router bgp 111
show ip bgp summary
show ip bgp
Regards.
