BGP routes received from neighbour,but not installed in routing table
gabelz
HI all,
just a question about BGP routing on NX-OS,
ISP3 is correctly sending routes to ISP1 and ISP1 is correctly receiving:
Now the issue is that all the routes coming from R3-1:
*>e10.10.10.0/24 70.70.70.2 0 100 3333 i
*>e10.20.20.0/24 70.70.70.2 0 100 3333 i
*>e10.30.30.0/24 70.70.70.2 100 3333 i
*>e70.70.70.0/30 70.70.70.2 0 100 3333 i
are not present in ISP1 routing table:
GNS3 enviroment,Cisco NX-OSv 7.30.
Any suggestion?
Thanks in advance,
MG
Hi @gabelz ,
It is a bit different under NXOS. Try the following:
router bgp 4444
neighbor 30.30.30.1
address-family ipv4 unicast
next-hop-self
8 Replies 8
Check below
Thanks A Lot
MHM
Harold Ritter
Hi @gabelz ,
On router ISP3, you need to use
next-hop-self
on neighbor configuration to ISP1.
HI @Harold Ritter ,
i already tried command ,but no luck:
thanks for your time!
MG
Hi @gabelz ,
router bgp 4444
neighbor 30.30.30.1
next-hop-self
Hi @Harold Ritter ,
worked only adding remote-as to neighbour string or it stayed in idle,but ,anyway,that was the solution.
Many thanks!
MG
No need to see config'
I know the correct issue.
gabelz
Hi there,
thanks for your answer,70.70.70.0/30 is the P2P between R3-1 router (not NSK) and NSK ISP3 and route 70.70.70.0/30 is present in both and advertised trough BGP to all the ISPs NSK in the backbone(ISP1 AND ISP2),but the problem that all the routes coming from R3-1 are ADVERTISED correctly to ISP routers,RECEIVED correctly from ISP routers,but are not present in the routing table.
Thanks in advance,
MG
Yes it receive from ISP but see the next hop' the next hop is also receive via bgp it not appear as directed connect nor as static nor igp.
Check 70.70.70.x
Thanks A Lot
MHM
