BGP Routing Protocol
Hello!
I have a question about BGP, is there a way to receive same prefixes from one router by different BGP peers as different best paths that connected to my router by sub interfaces? is there any technique regarding this case?
Thanks.
Giuseppe Larosa
Hello Mohammad,
the eBGP paths must have a tie (same value)  on the first BGP attributes:
same weight
same local-preference
same AS path length
same origin code (i or ?)
same MED  (if using bgp always-compare-med)
then under router bgp you issue
maximum-paths 4
Note: a single best path is still chosen by BGP but if there is a tie on first BGP best path selection criteria multiple BGP routes can be installed in the IP routing table
Hope to help
Giuseppe
