BGP routing table is not showing all routes
the_crooked_toe
I have a point-to-point connection between 5 cities and I am trying to run BGP between them.
Each city has these subnets associated with them
City 1 = 10.110.0.0
City 2 = 10.120.0.0
City 3 = 10.130.0.0
City 4 = 10.140.0.0
City 5 = 10.150.0.0
Router 1 is the main Point-to-Point router that has the connection to every router. If Router 2 wants to get to Router 4, it must go through Router 1.
On each router, i have a static route set for anything on that subnet to go back to the city's core router
for instance, Router 1 that has an ip address of 10.110.2.1 and has this static route.
ip route 10.110.0.0 255.255.0.0 10.110.2.2
the BGP configuration is like this on router 1
router bgp 64834
no synchronization
no auto-summary
network 10.110.0.0 mask 255.255.0.0
neighbor 10.120.2.1 remote-as 64834
neighbor 10.130.2.1 remote-as 64834
neighbor 10.140.2.1 remote-as 64834
neighbor 10.150.2.1 remote-as 64834
default-information originate
routers 2 through 5 have this type of configuration
router BGP 64834
no synchronization
no auto-summary
network 10.120.0.0 mask 255.255.0.0
neighbor 10.110.2.1 remote-as 64834
When i do a 'sh ip route' and a 'sh ip bgp' on Router 1 , it can see all the routes correctly.
When i do a 'sh ip route' on routers 2 through 5
it can only see its route and the route to router 1.
For instance.
a 'sh ip route' on router 2 can see its own network 10.120.0.0 and can see the neighbor routers network 10.110.0.0, but it cannot see router 3, 4 or 5s routes. It seems as if router 1 is not distributing the routes it receives from other cities.
Is there some type of configuration that I'm not setting up correctly?
TIA
royalblues
Level 10
Level 10
The problem is due to split horizon rule of BGP.
BGP does not forward an IBGP learned route to another IBGP peer by default. There are 2 ways to overcome this, either run a full mesh or use route-reflectors
On Router 1 add the following
router bgp 64834
neighbor 10.120.2.1 route-reflector-client
neighbor 10.130.2.1 route-reflector-client
neighbor 10.140.2.1 route-reflector-client
neighbor 10.150.2.1 route-reflector-client
Narayan
Narayan,
Thanks for the suggestion, I will try that tonight when I have time to take down the network.
I will report back with what I find.
Thanks!!
