bgp sample config
rajeshk200_2
Hi all,
can anybody give sample bgp config for.
two routers (linked thro internal thro wan connection) with two diffrent ISP .
Rajesh
5 Replies 5
vladrac-ccna
Level 5
Level 5
sean
Level 3
Level 3
These configs are based off of dedicated Internet routers with iBGP peers to an internal router.
Connection for ISP A:
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 10.0.0.0 mask 255.255.255.0
network 10.20.0.0 mask 255.255.255.0
neighbor 1.1.1.1 remote-as 65003
neighbor 1.1.1.1 description [ISP-A]
neighbor 1.1.1.1 filter-list 1 out
neighbor 10.0.0.2 remote-as 65001
neighbor 10.0.0.2 description [Internal-Router]
neighbor 10.0.0.2 update-source Loopback0
neighbor 10.0.0.2 next-hop-self
no auto-summary
ip as-path access-list 1 permit ^$
ip as-path access-list 1 deny .*
Connection for ISP B:
router bgp 65001
no synchronization
neighbor 2.2.2.1 remote-as 65004
neighbor 2.2.2.1 description [ISP-B]
neighbor 2.2.2.1 filter-list 1 out
no auto-summary
Internal router connection to each Internet router:
router bgp 65001
no synchronization
neighbor 10.0.0.1 remote-as 65001
neighbor 10.0.0.1 description [Internet-Router-A]
neighbor 10.0.0.1 update-source Loopback0
neighbor 10.0.0.1 next-hop-self
neighbor 10.0.0.3 remote-as 65001
neighbor 10.0.0.3 description [Internet-Router-B]
neighbor 10.0.0.3 update-source Loopback0
neighbor 10.0.0.3 next-hop-self
no auto-summary
Hope this helps.
hi Sean,
Thanks for the response...is this config work if i have no direct link between two internet routers.
Is it mandatory to run ibgp session on internal router to internet routers?
u r using private AS Number ...with private AS # can we connect two different service providers?
Regards Rajesh
hello Rajesh,
You can run IBGP even if the internal router doesnt have direct link, as long as you have any IGP running.
Its not mandatory to run IBGP between the 2 routers.
And yes you can use private AS with no problems as the ISP can strip this information on its routers.
HTH,
please remember to rate helpful posts.
Vlad
sean
Level 3
Level 3
This was just an example. Instead of an iBGP peer between the two Internet routers, there are iBGP peers passing into an internal router (for redundancy, you could use two). This is overkill for some networks, but allows for more modularity and scalability in the network. Also allows for a central location for BGP to choose the best path based on both peers.
The use of iBGP is to pass the full internet tables into the internal device. This can only be done with BGP as no other protocol can handle that many routes.
I used private AS numbers as an example. For your config, you would need to use your ASN. If you do not have one, you can look at the requirements of obtaining one from (assuming you are in north america) http://www.arin.net Seems how you are trying to multi-home, you qualify for one as long as you have provider independent address space. Hope this helps. Let me know if you have anymore questions.
