BGP Scanner
mounir.mohamed
Level 7
Level 7
Dear All,
IN Cisco IOS, is there is seperated Scanners one for BGP and another one for MP-BGP!!! i beleive that because there is onlyBGP process per router so Practically there is only One Scanner also the output of show proc cpu | inc BGP shown that there is only one scanner running on the router while the router running BGP and MP-BGP session
155 4853192 28039604 173 0.00% 0.02% 0.00% 0 BGP Router
157 1834796 3016664 608 0.00% 0.01% 0.00% 0 BGP I/O
158 42596720 774281 55015 0.00% 0.31% 0.25% 0 BGP Scanner
So Kindly Clarify
Best Reagrds,
Mounir Mohamed
Harold Ritter
Mounir,
There is indeed one scanner for all address families.
Hope this helps,
mheusinger
Level 10
Level 10
there is one Scanner process in software, but you can instruct it to scan different address-families at different frequencies. The config could be like this (not complete for a PE, just to show bgp scan-time):
router bgp 65000
bgp scan-time 20
neighbor 10.1.1.1 remote-as 65000
address-family vpnv4
neighbor 10.1.1.1 activate
neighbor 10.1.1.1 next-hop-self
bgp scan-time 15
exit-address-family
Hope this helps! Please rate all posts.
Regards, Martin
Dear Mr Martin,
I have same problem my 12416 router doing  high CPU ..if i take full route then cup will be 100%.
kowsar
