bgp send routes <<< (recived) routes
arumalpra
I have two identical bgp peering in my vrf.
for both peering in PE, send routes are 237.
one peering has recieved 16665 routes but other only 225
BGP config (same for both peering)
neighbor xxxx remote-as xxxx
neighbor xxxx activate
neighbor xxxx route-map xxxx in
PE and first CE
PE
sh ip bgp vpnv4 vrf xxxxxxxxxxxxxxxxxxx neighbors xxxxxx  advertised-routes
Total number of prefixes 237
CE 1
sh ip bgp sum
Neighbor        V          AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
x.x.x.x           4         xxxx    3254     975      820    0    0 08:47:05                 225
PE and 2nd CE
PE
CE2
sh ip bgp sum
xx.xxx.xxx.xxx  4         xxxx   32203   32429    44555    0    0 1w6d        16665
Appriciate help.
arumalpra
suscpecting hardware problem....
cadet alain
on CE1 the BGP neighbourship is up since 08:47:05 whereas on CE2 it is since 1w6d so it could explain the different number of received prefixes.
Alain
