Cisco2911ccme/srst-k9
Anjali Devi
                   Team, recently i have raised an RMA for CISCO2911ccme/srst-K9, inturn i have received cisco2911/k9, now i do i convert this received RMA to CISCO2911CCM/SRST-K9
Subeh Sharma
Hi anjali,
Pleas rephrase your query as it is not clear what is it that you're looking for.
Subeh
paolo bevilacqua
First of all you can enable a temporary license to enable VoIP features including CCME/SRTS.
Then you will have to work with your cisco reseller to correct the mistake and acquire the above license permanenty.
Anjali Devi
How do get temoprary license and then how do we get permanent license.
Please help me in getting the link.
Sent from Cisco Technical Support Android App
Have a look at
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html, in particular the sections on 'Temporary Licenses' and 'RMA'.
