BGP session not forming
Isaac001
Dear community,
I have a lab with 3 routers. R3,R4 and R5. R3 and R5 have bgp configuration as below. I have eigrp 100 running on all the routers and there is reachiblity to all IPs. R4 is BETWEEN R3 and R5. why can't a bgp session be formed between R3 and R5?
R3
router bgp 65100
bgp log-neighbor-changes
neighbor 10.13.1.2 remote-as 65200
R5
router bgp 65200
no bgp default ipv4-unicast
neighbor 10.12.1.1 remote-as 65100
address-family ipv4
neighbor 10.12.1.1 activate
exit-address-family
BGP router identifier 192.168.3.1, local AS number 65100
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.13.1.2 4 65200 0 0 1 0 0 never Idle
I have attached the routing tables, thanks experts!
Isaac.
Harold Ritter
Hi @Isaac001 ,
Since this is an ebgp session you are trying to establish R3 and R5 you need to add the following configuration on R3 and R5.
R3:
router bgp 65100
neighbor 10.13.1.2 ebgp-multihop
R5:
router bgp 65200
neighbor 10.12.1.1 ebgp-multihop
post the full running configs (sh run) of all routers, as well as a schematic drawing of your topology that shows how the routers are connected (and which interfaces are connected to which interfaces)...
Harold Ritter
Hi @Isaac001 ,
R3:
router bgp 65100
R5:
router bgp 65200
Harold,
Thank you, configured it and it immediately came up!
Isaac.
You are very welcome @Isaac001 and thank you for the feedback
