bgp show ip bgp output
Amiana
I'm using the following topology
If I talk about the
 network 10.10.1.0/24 (PC1)
, R2 is receiving tow routes for this network. Why R2 chooses the second one as the best? Is because it has the best weight value?
What does it mean the keywords: Sourced, Internal, local?
the local and internal/external keyword explain please see below link
https://itectec.com/network/cisco-local-in-show-ip-bgp-output/
since the weight is first best path selection criteria and it high then Yes weight is effect here.
source because this router is not learn this route from BGP but it inject directly via
redistribute or network
Thank you for your answer
Why the output is saying that we both routes are best (#2)?
sorry which one? I see only one select as best in your sharing output.
