02-02-2022
08:14 AM
- last edited on
02-03-2022
10:00 PM
by
Translator
Current configuration : 1587 bytes
! Last configuration change at 14:42:17 UTC Wed Feb 2 2022 by admin
version 15.0
service password-encryption
hostname Router-01
boot-start-marker
boot-end-marker
enable password 7 0822455D0A16
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name HotelSpoorzicht.local
username admin password 7 030752180500
redundancy
ip ssh version 2
interface GigabitEthernet0/0
no ip address
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
ip address 10.10.30.1 255.255.255.0
interface GigabitEthernet0/0.40
encapsulation dot1Q 40
ip address 10.10.40.1 255.255.255.0
interface GigabitEthernet0/0.50
encapsulation dot1Q 50
ip address 10.10.50.1 255.255.255.240
interface GigabitEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/1 overload
access-list 10 permit 10.0.0.0 0.255.255.255
control-plane
line con 0
exec-timeout 0 0
password 7 00071A150754
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
scheduler allocate 20000 1000
end
Solved! Go to Solution.
02-02-2022
09:15 AM
- last edited on
02-03-2022
10:10 PM
by
Translator
add the lines marked in bold to your configuration:
version 15.0
hostname Router-01
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
redundancy
ip ssh version 2
no ip address
ip nat inside
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
--> ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip http server
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 dhcp
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
end
02-02-2022 08:21 AM
NAT with DHCP. Can´t you put an IP address there? Dont think is going to work.
interface GigabitEthernet0/1 ip address dhcp ip nat outside ip virtual-reassembly duplex auto speed auto
02-02-2022
08:50 AM
- last edited on
02-03-2022
10:08 PM
by
Translator
Hi Flavio!
The GigabitEthernet0/1 is my link to the WAN(Internet) so if I do not use a
DHCP I won't be able to get an IP address from the WAN side.
02-02-2022
09:10 AM
- last edited on
02-03-2022
10:06 PM
by
Translator
Got it.
You should have a route on the router like this:
0.0.0.0 0.0.0.0 >> ISP
Considering you dont know your gateway IP address, then, try to put interface GigabitEthernet0/1
02-02-2022
09:27 AM
- last edited on
02-04-2022
12:15 AM
by
Translator
I tried to do that at first, but for some reason I when i did
show IP route
, I show that a static default route was configured with the next hop as the WAN IP address but I tried configuring one manually but that did not help as well.
02-02-2022 08:50 AM
The GigabitEthernet0/1 is my link to the WAN(Internet) so if I do not use a DHCP I won't be able to get an IP address from the WAN side.
02-02-2022
09:15 AM
- last edited on
02-03-2022
10:10 PM
by
Translator
version 15.0
hostname Router-01
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
redundancy
ip ssh version 2
no ip address
ip nat inside
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
--> ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
end
02-02-2022 09:40 AM
Thank you for your message but I would like to know why I have to add those lines.
Thanks anyways
02-02-2022 09:49 AM
the title of your post is:
--> My PAT(NAT overload) is not working
These lines are basic NAT configuration. The router needs to know what the inside NAT enabled interface are.
02-02-2022
11:38 AM
- last edited on
02-03-2022
10:11 PM
by
Translator
Hello
ip nat inside = this specifys the inside nat domains (interfaces -real ip subnets) that you wish to be translated
ip nat outside = this specifys the outside nat domains (public facing interfaces) which outside hosts will connect to
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 dhcp= is required to route any non local destination traffic via the public wan interface.
When translation occurs inside > outside then local inside real ip address will be translated to the public routable outside interface ip address,
The rtr will perform a route lookup and see the destination address of the traffic is via the wan (outside) interface, as traffic is routed towards the outside interface (via the default static route) a network translation will be performed real ip address <> translated ip address
Any outside hosts receiving traffic from your router will see the source ip originating from your rtrs outside interface so any return traffic will have a destination address of your public wan ip address
For the return traffic as it arrives at your router, the router will see it has a translation entry for that destination port/address, it will perform the translation from public ip address into the real ip address of your inside host and then perform a route lookup to forward that traffic onwards to real ip address/port of the inside host.
