09-14-2017 06:37 PM - edited 03-05-2019 09:08 AM
Hi all,
i have questions:
1. Who will take precedence if route refresh is supported by my router and neighbor but i still configured it with soft-reconfiguration inbound? is there any article from cisco?
2. if soft-reconfiguration inbound takes precedence then how would i refresh my peer if new outbound policy is applied? like AS path prepend, i only see clear ip bgp 192.168.1.1 soft in how about my outbound?
Thanks all
Solved! Go to Solution.
09-14-2017 08:02 PM
I think you are misundestanding the concept of route refresh and soft-reconfiguration inbound.
Route refreash is part of the OPEN message sent:
-BGP Version (usually version 4)
-BGP AS Number
-Hold Time
-BGP Identifier (BGP router-id)
-Optional Parameters (includes the router’s BGP capabilities, such as; authentication, multi protocol support, & route-refresh)Which means, with all others parameters, router ask an route-refresh.
Soft-reconfiguration inbound is used when route-refresh is not supported. So, is it not possible to have conflit considering you are not going to use both at the same time.You may want to read this:
This document start with the following statement:
This document explains behaviour of Cisco routers running IOS-XR when configuring soft-reconfiguration Inbound
Possible scenarios:
1. - When the BGP neighbour is not route refresh capable:
09-14-2017 08:02 PM
-BGP AS Number
-Hold Time
Possible scenarios:
