BGP Soft reconfiguration on ASA
cyodesigns
I'm running BGP on an ASA 5512-X (Version 9.7(1))
I am trying to see the received routes from a BGP peer before filtering is applied, however I receive this error:
# show bgp neighbors 192.168.198.2 received-routes
% Inbound soft reconfiguration not enabled on 192.168.198.2
I've tried to find out how to enable soft-reconfiguration but I can't see an ASA equivalent of the IOS command:
neighbor 10.232.1.1 soft-reconfiguration inbound
Anyone know how to enable soft-reconfiguration on an ASA?
Mark
2 Accepted Solutions
Philip D'Ath
I can't find this command even in the 9.6 ASA BGP manual.  I'm guessing it has not been implemented yet.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/route-bgp.html
Julio E. Moisa
Try to open the discussion under the security or firewall category. I was trying to find the command but I think it could be a BGP limitation on ASA.
https://supportforums.cisco.com/community/4561/security
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Philip D'Ath
Julio E. Moisa
bogdan.sileanu
That command, even if showing up in '?' is not supported on ASA. Instead use:
"#show bgp neighbors X.X.X.X routes"
replace x.x.x.x with your actual neighbor(s) - 192.168.198.2 , 10.232.1.1
Wouldn't this command show bgp neighbors X.X.X.X routes only show you routes post filter?
Correct.
