ISR4400 No files in directory
ardit
Hello Together
I have the router type: ISR4400
I wanted to output the "bootflash:" with the command "you"
The error message:
r-****#dir bootflash:
Directory of bootflash:/
7113240576 bytes total (3392778240 bytes free)
r-****#dir all-filesystems
Directory of system:/
    2  -r--                0                    <no date>  default-running-config
    4  dr-x                0                    <no date>  memory
    1  -rw-             8834                    <no date>  running-config
    3  dr-x                0                    <no date>  vfile
No space information available
Directory of tmpsys:/
   73  drw-                0                    <no date>  call-home
    6  drw-                0                    <no date>  eem_lib_system
    5  drw-                0                    <no date>  eem_lib_user
   18  -rw-                0                    <no date>  eem_pnt_0
   20  -rw-                0                    <no date>  eem_pnt_1
   38  -rw-                0                    <no date>  eem_pnt_10
   40  -rw-                0                    <no date>  eem_pnt_11
   42  -rw-                0                    <no date>  eem_pnt_12
   44  -rw-                0                    <no date>  eem_pnt_13
   46  -rw-                0                    <no date>  eem_pnt_14
   48  -rw-                0                    <no date>  eem_pnt_15
   22  -rw-                0                    <no date>  eem_pnt_2
   24  -rw-                0                    <no date>  eem_pnt_3
   26  -rw-                0                    <no date>  eem_pnt_4
   28  -rw-                0                    <no date>  eem_pnt_5
   30  -rw-                0                    <no date>  eem_pnt_6
   32  -rw-                0                    <no date>  eem_pnt_7
   34  -rw-                0                    <no date>  eem_pnt_8
   36  -rw-                0                    <no date>  eem_pnt_9
    4  drw-                0                    <no date>  eem_policy
    8  drw-                0                    <no date>  eem_pub
   17  -rw-                0                    <no date>  eem_rpc_0
   19  -rw-                0                    <no date>  eem_rpc_1
   37  -rw-                0                    <no date>  eem_rpc_10
   39  -rw-                0                    <no date>  eem_rpc_11
   41  -rw-                0                    <no date>  eem_rpc_12
   43  -rw-                0                    <no date>  eem_rpc_13
   45  -rw-                0                    <no date>  eem_rpc_14
   47  -rw-                0                    <no date>  eem_rpc_15
   21  -rw-                0                    <no date>  eem_rpc_2
   23  -rw-                0                    <no date>  eem_rpc_3
   25  -rw-                0                    <no date>  eem_rpc_4
   27  -rw-                0                    <no date>  eem_rpc_5
   29  -rw-                0                    <no date>  eem_rpc_6
   31  -rw-                0                    <no date>  eem_rpc_7
   33  -rw-                0                    <no date>  eem_rpc_8
   35  -rw-                0                    <no date>  eem_rpc_9
    7  drw-                0                    <no date>  eem_temp
    1  dr-x                0                    <no date>  lib
    9  drw-                0                    <no date>  macro_scripts
Directory of nvram:/
32769  -rw-             8906                    <no date>  startup-config
32770  ----             4362                    <no date>  private-config
32771  -rw-             8906                    <no date>  underlying-config
    1  ----              458                    <no date>  persistent-data
    2  -rw-             1182                    <no date>  ISR4431-X-4x1GE_0_0_0
    4  -rw-               17                    <no date>  ecfm_ieee_mib
    5  -rw-                0                    <no date>  ifIndex-table
33554432 bytes total (33535992 bytes free)
What can I do to fix this?
I don't dare to restart.
Leo Laohoo
Download the IOS file from the Cisco website.
Use a USB (because this method is faster) thumb drive and transfer the IOS to the router.
Make sure the config registry value is 0x2101 (so you won't need to bother about the correct boot variable string).
Hello Leo Laohoo
Thanks for your answer.
I can't access it locally, I have to solve it via SSH.
Unfortunately I can't insert USB, but i can use FTP.
The boot variable 0x2101 starts the router in Rommon mode, or am I wrong?
0x2101 = "ignore boot variable & boot the first valid IOS file found in the bootflash:".
I'll try it.
Thanks!
