BGP state of down sessions is only IDLE (I don't see Active-state)...
kozorezdi
Hello everybody,
Down BGP sessions stay in only IDLE state by command : sh ip bgp summary.  The router knows the path to the neighbor.   For example:
80.81.192.A   4 2528B       0       0        0    0    0 01:31:26 Idle
#ping 80.81.192.A
Sending 5, 100-byte ICMP Echos to 80.81.192.202, timeout is 2 seconds:
!!!!!  Success rate is 100 percent (5/5)
I don't see them as Active and it is strange to me...
Could you explain it?
#sh ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 24-Feb-09 23:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD1, RELEASE SOFTWARE (fc4)
Router01 uptime is 26 weeks, 1 day, 15 hours, 34 minutes
Uptime for this control processor is 26 weeks, 1 day, 15 hours, 47 minutes
System returned to ROM by reload at 15:34:25 UTC Tue Feb 24 2009 (SP by reload)
System restarted at 17:05:40 UTC Tue Jul 28 2009
System image file is "bootdisk:c7600s72033-advipservices-mz.122-33.SRD1.bin"
Last reload type: Normal Reload
cisco CISCO7609 (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID FOX103107NH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
5 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thank you in advance!
Have a nice day,
Dmitry
Giuseppe Larosa
Hello Dmitry,
post
sh ip bgp neigh 80.81.192.A
be aware that if you are trying to setup an eBGP session between not directly connected (using a loopback source) you need
neigh 80.81.192.A ebgp-multihop 2
or other side has not configured the eBGP session or removed their configuration
Hope to help
Giuseppe
Hello Giuseppe,
no wrong again
it is direct eBGP peering 80.81.192.C (our ip on DECIX) and 80.81.192.B(remote-AS).
I know that session is exist on remote side, but it down (because of leak of prefixes from my AS).
anyway it should be most time in Active state and just a few seconds in Idle state, at least it was on another models/IOS.
thank you.
#sh ip bgp neighbor 80.81.192.A
BGP neighbor is 80.81.192.A,  remote AS B, external link
Description: C
  BGP version 4, remote router ID 80.81.192.A
  BGP state = OpenSent
  Last read 00:00:00, last write 00:00:00, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    0 active, is multisession capable
  Message statistics, flags active, state OpenSent:
    InQ depth is 2
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          0
    Notifications:          0          0
    Updates:                0          0
    Keepalives:             0          0
    Route Refresh:          0          0
    Total:                  1          0
  Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
  Session: 80.81.192.A active
  BGP table version 73660861, neighbor version 0/0
  Output queue size : 0
  Index 2, Offset 0, Mask 0x4
  2 update-group member
  Inbound soft reconfiguration allowed
  NEXT_HOP is always this router
  Inbound path policy configured
  Outbound path policy configured
  Route map for incoming advertisements is DE-PEER-DECIX-in
  Route map for outgoing advertisements is DE-PEER-DECIX-out
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:             155          0
    Prefixes Total:                 0          0
    Implicit Withdraw:              0          0
    Explicit Withdraw:              0          0
    Used as bestpath:             n/a          0
    Used as multipath:            n/a          0
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    Total:                                0          0
  Maximum prefixes allowed 3000
  Threshold for warning message 75%
  Number of NLRIs in the update sent: max 625, min 0
  Address tracking is enabled, the RIB does have a route to 80.81.192.A
  Connections established 10; dropped 10
  Last reset 00:41:55, due to NSF peer closed the session of session 1
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is enabled, restart-time 120 seconds, stalepath-time 360 seconds
  No active TCP connection
Have a nice day,
Dmitry
Hey Dmitri,
There is possibility that ur physical interface is down. in that case too, bgp state will remain in IDLE.
Its FUN !!!
Krushang
