11-06-2012 06:27 AM - edited 03-04-2019 06:03 PM
Hi all
If I have 2 providers A and B, that both send me a default route
If I want to make sure inbound traffic comes to router A, do I just prepend my AS path to ISP B?
How reliable is this ? and would I just prepend it once ?
cheers
11-06-2012 09:09 AM
Yes if you advertising your network to both service providers. prepend will insure you get inbound on Router A. However there is no fixed rule how many times .3-4 times should be fine depends upon ISP peering.
11-15-2012 02:19 AM
how does this actually work? if im provider B, I gather that to get to my network once prepended I would have to go via provider A ? what if there was more paths going this way still? would it go direct from provider B still?
thats what I mean by, how reliable is it ?
11-15-2012 04:37 AM
Shortest AS path is always prefered so by doing prepend you make it longer.Hope this make sense.
11-16-2012 07:28 AM
The reliability is solid. It is dynamic which requires no manual intervention.
If provider B receives the announcement with a prepend, it will announce this upstream and all routers will hold this information in the BGP table. Keep in mind that the best route is added to the routing table so the route to your site inbound will prefer provider A because that is the route that will be added to the routing table, which is the table used to route the traffic. The BGP table will hold both announcements though so if you do a sh ip bgp
11-16-2012 07:23 AM
Hi all
cheers
Carl - is there a reason you are concerned with Asymmetric routing? Does it matter if you go out one connection and back in another?
Inbound is a bit tricky in how you achieve this. If you prepend your announcement then yes you will prefer one link inbound and will not get any routes on the connection being pre-pended. If that is what you want then that will work. Outbound you can do the same thing with local pref. The higher the local pref the more preferred outbound.
PE A <------Inbound traffic preferred
CE
PE B (AS 1234, 1234, 1234) <------Multiple pre-pends will not accept inbound traffic until PE A is down or least preferred for any other reason
Local Pref 100 PE A (outbound traffic not used unless pref is changed higher or PE B goes down
CE
Local Pref 200 PE B ----------> (outbound traffic preferred - higher pref)
So if you want to prefer one connection over the other for both inbound and outbound, change the local pref and pre-pend the announcement.
To prefer PE A do the following:
Local Pref 200 PE A <----------> Outbound and Inbound traffic preferred
CE
