BGP to OSPF - NSSA default information originate - conditional
Bilal Nawaz
I have an ASBR and another router within the same NSSA area. The ASBR has a BGP peering with ISP and is receiving prefixes 0.0.0.0/0 and 1.0.0.0/24.
1.0.0.0/24 is not in the ISP AS, but learned route from another AS.
I know that when I issue the command 'area 254 nssa default-information-originate', a default route is generated in to the nssa area which is fine. However, I want to have the option to do this command 'default-information originate route-map AS1_DEFAULT_IF1'
This would say inject the default route downstream only if 1.0.0.0 is in the routing table. But when command is issued, this doesn't work. Could anyone tell me why this doesn't work?
I'm trying to follow this document, on section 6-14 at the bottom https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/3423-102-1-9434/ccmigration_09186a008014ee4e.pdf
In this case it is suggested the NSSA area is used, what harm is there if I use a normal area (not area 0). Because the non NSSA solution will work fine.
ASBR:
router ospf 254
log-adjacency-changes
area 254 nssa
default-information originate always route-map AS1_DEFAULT_IF1
ip prefix-list bgplist seq 5 permit 1.0.0.0/24
route-map AS1_DEFAULT_IF1 permit 10
match ip address prefix-list bgplist
show ip route
B*   0.0.0.0/0 [20/0] via 172.16.10.1, 10:00:07
B       1.0.0.0 [20/0] via 172.16.10.1, 09:56:20
O       172.16.252.0 [110/20] via 172.16.254.2, 00:21:48, FastEthernet0/0
C       172.16.254.0 is directly connected, FastEthernet0/0
C       172.16.10.0 is directly connected, FastEthernet0/1
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
15 Replies 15
Hello Jose,
Sorry, my mistake. I thought that Bilal used nssa area only because example in pdf used it.
Now we can leave this thread rest in peace
Best Regards
Please rate helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
