BGP:Understanding the difference between 'network' vs 'aggregate'
news2010a
Level 3
Level 3
Folks, can you please clarify the question in blue below.
Goal:Imagine I want to advertise network 155.4.0.0/16 to AS 54. I have two functional routers like this:
BB1 (AS 54) ---------------  R6 (AS 100)
If I do 'aggregate-address' on R6 like shown below, I go to BB1 and do 'show ip route 155.4.0.0 255.255.0.0' on BB1 and see the route is learned - OK.
#R6
router bgp 100
aggregate-address 155.4.0.0 255.255.0.0
Then I attempted to use the 'network' statement to advertise such route instead. I did:
#R6
router bgp 100
network 155.4.0.0 mask 255.255.0.0
I observe that BB1 does not learn the 155.4.0.0 route.
Question:
What am I missing?
I expected that when I advertised the 155.4.0.0/16 prefix on R6 via the 'network' statement, BB1 could learn that as well. It did not.
From reading the documentation is not clear to me the justification for this behavior.
Rack4R6#show run | s eigrp 100
router eigrp 100
network 155.4.0.0
no auto-summary
Rack4R6#
Rack4R6#show run | s bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
network 155.4.0.0
network 155.4.146.0 mask 255.255.255.0
neighbor 54.4.1.254 remote-as 54
neighbor 155.4.146.1 remote-as 100
neighbor 155.4.146.1 next-hop-self
no auto-summary
Rack4R6#show ip route 54.4.1.254
Routing entry for 54.4.1.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via Serial0/0/0
      Route metric is 0, traffic share count is 1
2 Accepted Solutions
Giuseppe Larosa
Hello Marlon,
when you have "no auto-summary" the network command requires an exact match in IP routing table.
aggregate-address command creates an aggregate when at least one component route is in the BGP table by a network or by redistribution of an IGP.
it is a form of route summarization. Before aggregate-address command was introduced the only way to create an aggregate address was:
ip route 155.4.0.0 255.255.0.0 null0
router bgp xx
network 155.4.0.0 netmask 255.255.0.0
the aggregate created in this way is never withdrawned, with aggregate-address command when last component route disappears the aggregate is removed.
Hope to help
Giuseppe
Jon Marshall
#R6
router bgp 100
#R6
router bgp 100
Question:
What am I missing?
router eigrp 100
network 155.4.0.0
no auto-summary
Rack4R6#
router bgp 100
no synchronization
network 155.4.0.0
no auto-summary
Marlon
If you do a "sh ip route" on R6 is there a routing entry for the 155.4.0.0/16 network. There has to be a matching route in the IGP table when you use a "network" statement under BGP or it will not be advertised.
Aggregate is slightly different in that there does not have to be a match but rather as long as one of the subnets with 155.4.0.0/16 is the routing table it will be advertised.
So it sounds like that your are missing a router.
On R1 try adding this -
ip route 155.4.0.0 255.255.0.0 Null0
and see if it is then advertised out. Note that i'm assuming this is a lab setup ?.
Jon
Giuseppe Larosa
Hello Marlon,
router bgp xx
Hope to help
Giuseppe
Jon Marshall
#R6
router bgp 100
#R6
router bgp 100
Question:
What am I missing?
router eigrp 100
network 155.4.0.0
no auto-summary
Rack4R6#
router bgp 100
no synchronization
network 155.4.0.0
no auto-summary
Marlon
Jon
Ah!!! so then the aggregate-address is different that it dispenses that IGP match condition - although I realize I must advertise one prefix (i.e.155.4.146.0/24) in order to make it work.
Thanks very much. That makes more sense now. From reading the documentation that was not obvious to me.
Yes, this is a lab so we are good making changes.
