Redirecting traffic from firewall?
bwhite123
Hi I have a system that involves two devices plugged into a cisco asa 5540 firewall.  A program on the device on the inside sends traffic to the device on the outside at a specific ip address 192.168.11.11 for instance.  Is there a way that I can redirect this traffic to a different IP?
interface GigabitEthernet0/0
nameif Outside
security-level 0
ip address 10.5.0.111 255.255.255.0
interface GigabitEthernet0/1
nameif Inside
security-level 100
ip address 10.10.0.10 255.255.255.0
igmp forward interface Outside
Giuseppe Larosa
unfortunately ASA doesn't support PBR policy based routing you need a router for this job.
see
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ip.html
Hope to help
Giuseppe
So there is no way to direct all traffic being sent to one IP to another on the ASA 5540?
t4tauseef33
PBR is not availble in firewall but with applying nat you could achieve this. its all depends upon the infrastructure you have. if you tell me briefly what are the gateways and whether you have access to the gateways then i could see the possible way of doing that.
The gateway is 192.168.11.1 on the receiving computer.
