BGP Updating Peer
opnsgreg
Greetings everyone,
During a cut this weekend I wanted to aggregate our class C advertisements.
The original config was
router bgp 12345
network xx.yy.zz.0
network xx.yy.za.0
The new config was
router bgp 12345
network xx.yy.zz.0/23
My reasoning was that this syntax would advertise both of our class C's. However, when the BGP session established, while I received all external routes from the upstream peer the peer received none from me. On further examination my router was not sending updates. If I returned to the original....ie not forcing a mask...it worked. So my question is, do you have to "define" the network first before either aggregating or splitting A's, B's, or C's, or is there something else I'm missing? I would also like to advertise only 3/4 of our Class B as well but had the same issues.
Greg
2 Accepted Solutions
Hi Greg,
When u use n/w command, it will look for exact prefix in routing table until autosummary is disabled. So first u chk ur own bgp table whether the roots that u expected are there or not???
Rgs,
Greg
I would suggest that you put in statics that match the prefix and mask that you want to advertise. It will work better that way.
Rick
Rick
7 Replies 7
vladrac-ccna
Level 5
Level 5
this is quite simple
keep the first 2 networks and add
aggregate-address xx.yy.zz.0 255.255.254.0 summary-only
Vlad
Vlad,
Thanks.....what about splitting though, ie I want to take a class B and only advertise 3/4 of it? I tried
network 123.456.0.0/17
network 123.456.128.0/18
but had the same advertisement issues (ie my router did not update the peer).
Thanks again,
Greg
Hi Greg,
Rgs,
Ooh, that's making sense. The router has a static which points the entire class B to the next internal hop. So, is the best idea to turn off auto summary or replace those statics with *exactly* the same routes I want to advertise?
Thanks again,
Greg
Greg
Rick
Rick
Hi Greg,
Even u can have a static route pointing to null0 provided if u own the whole subnet u r advertising.....
Rgs,
Thank you everyone for your replies, it really helped. I will try the statics.
Thanks again,
Greg Schaffer
