07-17-2006 09:08 AM - edited 03-03-2019 01:21 PM
Has anyone configured multicasting routing to work with Symantec Ghost-multicast successfully?
I would appreciate any specific configuration guidelines and tips. Should I use dense-mode, sparse-mode, a combination of both? How should I configure the routers? How should I configure the Layer-2 switches?
Thanks in advance!
07-17-2006 09:16 AM
see the following links for multicast configuration guides:
http://www.cisco.com/en/US/tech/tk828/tech_configuration_guides_list.html
PIM sparse-dense may probably be best for your scenario.
07-17-2006 11:49 AM
It is usually recommended to keep the Ghost server as close as possible to the PCs you want to ghost because of the amount of traffic generated by a PC imaging application. For that reason the default TTL for packets generated by the Ghost server is 1. That being said if you do decide to increase the default TTL and to have your PCs several hops away from the server, you should at least make sure you use sparse mode.
Hope this helps,
