06-11-2017 03:02 AM - edited 03-05-2019 08:41 AM
Hi Guys,
I have a question regarding VPNv4 route reflector.
I have router R1, R2 and R3. R2 is the vpnv4 route reflector.
I have created a vrf which has same RD, same Export and Import route targets in all 3 routers.
All routers are sending and receiving communities.
R2 who is the route reflector learns all VPNv4 routes from R1 and R3 but R3 does not pass R1 routes to R3
Should the VPNv4 route reflector be reflecting these routes between R1 and R2 ?
Solved! Go to Solution.
06-14-2017 06:00 PM
it was a pleasure, please keep me posted.
06-11-2017 04:31 AM
May I know your configuration? the route-reflector configuration should be under the Address family for the specific VRF. If the 3 routers are iBGP they should exchange prefixes.
06-11-2017 02:38 PM
06-11-2017 02:51 PM
Thank you
Could you please execute this command on R2
show bgp vpnv4 unicast all summary
Are these routers PE? usually Router-reflector is not need for a MPLS L3VPN environment, may I know the reason for this configuration?
06-11-2017 04:46 PM
Yes all routers are PE except R2 who is only the router reflector.
The reason is i will add more PE routers later into the network and do not want a full mesh network instead peer all routers to the RR.
Below is your show result
BGP router identifier 10.151.80.225, local AS number 3999
BGP table version is 6, main routing table version 6
3 network entries using 456 bytes of memory
3 path entries using 240 bytes of memory
2/2 BGP path/bestpath attribute entries using 304 bytes of memory
1 BGP extended community entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1024 total bytes of memory
BGP activity 3/0 prefixes, 3/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.151.80.227 4 38198 112 115 6 0 0 01:38:47 1
10.151.80.229 4 38198 111 114 6 0 0 01:38:38 1
06-11-2017 05:50 PM
The issue can be on the labeling, probably the prefixes from R1 and R3 are losing the MPLS Labels.
Have you configured LDP on the interfaces between the 3 routers?
06-11-2017 06:26 PM
Here my example where Router 1 is the RR Server:
R2 ---- R1 ---- R3
Router 1 (RR Server)
interface Loopback100
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.0.12.1 255.255.255.0
duplex auto
speed auto
mpls ip
interface FastEthernet0/1
ip address 10.0.13.1 255.255.255.0
duplex auto
speed auto
mpls ip
router ospf 100
mpls ldp autoconfig
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
router bgp 100
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 100
neighbor 2.2.2.2 update-source Loopback100
neighbor 3.3.3.3 remote-as 100
neighbor 3.3.3.3 update-source Loopback100
address-family vpnv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 send-community extended
neighbor 2.2.2.2 route-reflector-client
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 send-community extended
neighbor 3.3.3.3 route-reflector-client
exit-address-family
ip forward-protocol nd
mpls ldp router-id Loopback100
Router 2
ip vrf A
rd 1:1
route-target export 1:1
route-target import 1:1
interface Loopback0
ip vrf forwarding A
ip address 2.2.2.2 255.255.255.255
ip address 10.0.12.2 255.255.255.0
duplex auto
speed auto
mpls ip
no ip address
shutdown
duplex auto
speed auto
router ospf 100
mpls ldp autoconfig
router bgp 100
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 update-source Loopback100
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
address-family ipv4 vrf A
no synchronization
network 2.2.2.2 mask 255.255.255.255
exit-address-family
Router 3
ip vrf A
rd 1:1
interface Loopback0
ip vrf forwarding A
ip address 3.3.3.3 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
ip address 10.0.13.3 255.255.255.0
duplex auto
speed auto
router ospf 100
mpls ldp autoconfig
router bgp 100
exit-address-family
no synchronization
network 3.3.3.3 mask 255.255.255.255
exit-address-family
06-12-2017 01:38 AM
thanks for sharing this ..
Were you able to see 2.2.2.2 route in R3 VRF A?
06-12-2017 04:50 AM
Yes, Im able. Please let me share the routing table from both routers.
06-12-2017 04:59 AM
R2#sh ip route vrf A
Routing Table: A
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.2.2 is directly connected, Loopback0
3.0.0.0/32 is subnetted, 1 subnets
B 3.3.3.3 [200/0] via 3.3.3.3, 00:00:06
R2#
R3#sh ip route vrf A
Routing Table: A
B 2.2.2.2 [200/0] via 2.2.2.2, 00:00:08
C 3.3.3.3 is directly connected, Loopback0
R3#
I recommend verify the MPLS Labels, Route-targets and the information you are advertising, remember if you are going to advertise a prefix from BGP the subnet mask must be the same on the routing table.
06-14-2017 05:44 PM
Thanks Julio.. I will check all this soon and revert.
06-14-2017 06:00 PM
06-20-2017 05:58 PM
thanks Julio was able to make this work
06-20-2017 06:07 PM
It was a pleasure my friend,
have a great day
06-11-2017 06:39 PM
Thank you for your reply.
Below is my mpls forwarding table
R3
show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
16 Pop Label 10.151.80.227/32 0 Et0/0 202.1.1.1
17 Pop Label 10.151.80.225/32 0 Et0/3 10.151.80.33
18 Pop Label 10.151.80.4/30 0 Et0/3 10.151.80.33
Pop Label 10.151.80.4/30 0 Et0/0 202.1.1.1
19 Pop Label 3.3.3.3/32[V] 0 aggregate/ICT
R1
16 Pop Label 10.151.80.225/32 0 Et0/3 10.151.80.6
17 Pop Label 10.151.80.32/30 0 Et0/3 10.151.80.6
Pop Label 10.151.80.32/30 0 Et0/0 202.1.1.2
18 Pop Label 10.151.80.229/32 0 Et0/0 202.1.1.2
19 Pop Label 1.1.1.1/32[V] 0 aggregate/ICT
R2
16 Pop Label 10.151.80.227/32 0 Et0/1 10.151.80.5
17 Pop Label 10.151.80.229/32 542 Et0/0 10.151.80.34
18 Pop Label 202.1.1.0/30 0 Et0/1 10.151.80.5
Pop Label 202.1.1.0/30 0 Et0/0 10.151.80.34
19 Pop Label 2.2.2.2/32[V] 0 aggregate/ICT
20 19 1.1.1.1/32[V] 0 Et0/1 10.151.80.5
21 19 3.3.3.3/32[V] 0 Et0/0 10.151.80.34
