BGP vs OSPF bs EIGRP (EGP vs IGP)
Umesh Shetty
Hi All,
Whenver there is a question asked on wht BGP is perferred on the internet as opposed to other routing protocols one reason I usually here is that BGP can process huge number of routes and SPF and DUAL cannot. Can someone please help me understand in detail why is it difficult for the SPF or DUAL process to process huge number of routes which BGP does so easily ?
Thanks in Advance
Umesh Shetty
6 Replies 6
mvsheik123
Level 7
Level 7
Hi Umesh,
Iam not sure on number of router parts but one reason- due to its best path selection algorithm (including loop avoidance) mechanism existance when compared to other IGP. lets see if experts can shed more light on your query.
Thx
MS
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
OSPF and EIGRP likely do more "computation" per "route" than BGP and they probably have much worse exponential computation growth, so it's a scalability issue.
For details of why there's a disparity, you would need to analyze the path selection algorithm and what their mathematical computation work formula is.  For instance, there's a huge difference between N squared vs. N log N as N increases.
Hi Joseph,
Can you please help me with a few more stromg reasons that would justify the use of BGP over other IGP's on the internet.
Thanks in Advance
Umesh Shetty
EIGRP is proprietary, so we can just rule that out.
BGP assumes some level of physical connectivity, and at least by some folks considered a routing by policy mechanisim as opposed to a routing by link state/cost.
OSPF would struggle to scale, for example how would you define area0 area xxx for something as dynamic as the internnet
Disclaimer
Posting
Not as it was.  See http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6554/ps6599/ps6630/qa_C67-726299.html
Disclaimer
Posting
Other than BGP scalability, the other notable feature of BGP is route policy management.  IGPs like OSPF and EIGRP pretty much treat all subnets alike, they just compute what the consider the best path between networks.  BGP, though, lends itself to "doing things" with routes.  What you might accept, what you'll pass along, how you will weight them, specific paths for specific networks, etc.
It's not uncommon to see even fairly large OSPF/EIGRP networks without any route policy management, but it's fairly common to see some kind of route policy management with BGP, except in the simplest usages.
