BGP with two links to one ISP
smailmilak
Level 4
Level 4
Hello guys,
we have two STM16 links to one ISP. The plan is to move from the Alcatel to the new Cisco router.
There are two static routes to the BGP neighbor with one BGP session. I am not sure how we should proceed on
the Cisco router. I have never seen a BGP setup with two static routes on any Cisco BGP implementation.
Should we use two static routes to one BGP neighbor or two BGP sessions to two BGP neighbors (different IP addresses)?
Is it better in this case to have a peering with the directly connected IP address or a loopback on the ISP side?
16 Replies 16
In this case the AS path prepend will not work, because we have iBGP peering (you and ISP use the same AS number). You could use MED (if your ISP looks at it of course) or conditional route advertising with BGP.
HTH.
Arber.
Hi Arber ,
I think I confused you guys , same as means both links are terminated on same AS no on ISP side .But ISP
as and customer AS numbers are diffrent .
I tryied below link config where i used static routes beween ISP and customer with highet AD value to
achive redundancy .please let me know if this will work here in practical env also as I checked this on GNS
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#co
nf2
my cust BGP config which has to be shifted on one ISP -
router bgp 99
bgp log-neighbor-changes
neighbor 119.26.12.7 remote-as 95
neighbor 119.26.12.3 description *** eBGP peering with SIFY ***
neighbor 119.26.12.3 version 4
neighbor 119.26.12.3 timers 10 30
neighbor 125.2.6.85 remote-as 94
neighbor 125.2.6.85 description ***BGP Peering with Bharti***
neighbor 125.2.6.85 version 4
neighbor 125.2.6.85 timers 10 30
address-family ipv4
  neighbor 119.26.162.3 activate
  neighbor 119.26.162.3 soft-reconfiguration inbound
  neighbor 119.26.162.3 prefix-list incoming in
  neighbor 119.26.162.3 route-map Sifynet out
  neighbor 125.22.36.8 activate
  neighbor 125.22.36.8 weight 65000
  neighbor 125.22.36.8 soft-reconfiguration inbound
  neighbor 125.22.36.8 prefix-list incoming in
  neighbor 125.22.36.8 route-map Bharti out
  no auto-summary
  no synchronization
  network 202.2.116.0 mask 255.255.254.0
  network 202.2.116.0
  network 202.2.117.0
exit-address-family
# pls dont trust on Ips here , i changed it .
