Billings
Hi.
I need that a router (1751-V) ticket the calls done by him to PSTN. However, it is not a srst and there is no call manager in the solution.
Does anybody know how I make this?
Thanks.
5 Replies 5
jackyoung
Level 6
Level 6
Did you have the VIC-2FXO module installed in the 1751-V ? It can provide the connectivity to connect to the PSTN (direct line) directly. If it is not direct line, you should check the compatibility of the voice module and your phone system.
Check here :
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088719.html
Hi Jack,
Yes, i have VIC-2FXO. And there is a direct line. So, i want billing these calls. How can I do?
What you need is a Phone Billing Machine such as availabe at
http://www.pepteller.com/billing-machine.html
It will be connected between your line and router
====Line===Billing_machine===Router_FXO
Hence all the calls originating from the router will give you a printout of the number as well as the time.This is similar to a PCO near your home.
Note: Pls make sure that terminating a call and chargable use of above setup is illegal in some countries.
Pls rate helpful posts.
JD
Hi JD.
I need and I want a way only with router Cisco.
A configuration.
Using snmp or syslog or other.
I believe the SNMP can log something but it may not able to log the exact info. that you want. And you may also need to interpert or filter out the unwanted info. Try to use some SNMP manager to poll the router and try.
