Binding DSL lines
DOUGLAS EVANS
Can you bind multiple DSL lines together like you can T-1s, with MLPPP ? or ?
DJE
pkhatri
Level 11
Level 11
You can certainly do multilink PPP over ATM. Here's a link to it:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/part30/ch05/qslfiatm.htm
I would appreciate you rating the post if it helps.
Paresh
