Configure serial port for additional Public IP's w/diff subnet
jeffreycascino
How do you configure your serial port for additional public IP's on a different subnet. Can you create a serial 0.1 I am sure this has been done I cannt figure it out.
Jeff
6 Replies 6
Richard Burts
Jeff
If you would explain a bit more about what you need and what your environment is we might be able to give better advice. For some media such as Frame Relay it may be possible to create subinterfaces such as serial0.1 and assign addresses to the subinterfaces. The other general solution is to use secondary addressing. It might look something like this:
interface serial 0
ip address 10.10.10.1 255.255.255.0
ip address 10.20.20.1 255.255.255.0 secondary
This allows both subnets to be active on the same interface at the same time. Would this provide what you need?
Rick
Rick
I think you got it. When I tryed it I received an error message that /28 for address 66.16.102.240 is Bad. I was suppose to receive an additional 16 addresses. That would make the subnet 28. Is it because my original subnet is 29 for the primary?
My original ip is 66.x.x.185/28
ip address 66.173.x.x.255.255.248
Any ideas?
Jeff
Rick,
You have been very helpfull but....
Following is my config. I can ping 66.16.102.241 but none of the other ip's work. I would think that I dont need a route statement in because of the gateway of last resort "ip route 0.0.0.0 0.x.x.x 66.x.167.57" Any ideas???
TechSupport#show run
Building configuration...
Current configuration : 710 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname TechSupport
enable secret 5
enable password
ip subnet-zero
interface FastEthernet0
ip address 66.16.x.x.255.255.240 secondary
speed auto
full-duplex
--More-- !
interface Serial0
ip address 66.173.x.x.255.255.252
encapsulation ppp
no fair-queue
service-module t1 clock source internal
ip classless
ip route 0.0.0.0 0.x.x.x.173.167.57
no ip http server
snmp-server community public RW
line con 0
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
Thanks for your help Jeff
Jeff,
You don't need a static route for that subnet as that's a directly connected network.
Do you have the PCs on the 66.16.102.240/28 subnet configured with the default gateway of 66.16.102.241? Ensure the PCs are configured with the correct subnet mask.
Pls. rate all helpful posts.
Sundar
Hello Jeff,
in addition to Rick's post, make sure that the hosts in the 66.16.102.242-254 IP address range have 66.16.102.241 configured as their default gateway. From where are you pinging anyway ?
GNT
Jeff
I am not sure that I am clear on what you are doing. It appears that you have at least three blocks of IP address space from your provider (subnet 66.173.167.56/30, 66.173.255.184/29, and 66.16.102.240/28). If that is right then I think the router config is about right. The default route that you configured should send everythig out to the provider. And traffic should get to you assuming that the provider is routing all three subnets to you.
The PCs in subnet 66.16.102.240 should use 66.16.102.241 as their default gateway while the PCs in 66.173.255.184 should use 66.173.255.185 as their deafult gateway.
If the above is true then there should be connectivity. If the above is not true then point out to me what is not. If there are still connectivity problems then help me understand better what does not work.
Rick
Rick
