Binding E1
bikash_bd
HI,
I want 8 mbps link. In this situation I want purchse one 2821 router and 4 VWIC-2MFT-E1 cards. How can I bind them so that It will work like one. Second,How can I load balance it.
Third, I have MWR 1941 router. How can I perform the above in this router . PLS Help ASAP.
minumathur
You need to configure multilink in router, give single ip address in multilink IP address with mask /30 & configure routing.
let me know anything more you required, please rate this post.
this link also help you, you need consider serail interface instead of dialer interface.
http://cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080093c1d.shtml
-minu
balajitvk
Level 4
Level 4
You can use multilink concept to bind all these E1 to work like one.....
There is a documentation for you to tell how to bind them,
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_configuration_example09186a00800a5efa.shtml
Itself enables the load-balancing of traffic from different links and allows some level of redundancy in case of a line failure on a single link.
Support of VWIC-2MFT-E1 on the platforms can be refered in the below document,
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091b9c.html
Cisco MWR 1941-DC router will support VWIC-2MFT-T1-DIR and multilink operation will be the same as other platforms
http://www.cisco.com/en/US/products/hw/routers/ps4062/prod_installation_guide09186a00801c9330.html
Rate if does,
Rgs.
