Block access between subnets in same VRF
Kudetauk77
Level 2
Level 2
Hi All
I am trying to figure a way out to use one VRF  for mutiple customers , some customers have only one or 2 sites , so I am thinking of a way I can put these sites/subnets in the same VRF and then be able to block access between the sites /subnets
There is probabaly a very obvious answer to this . The only way I can think at the moment would be on the CE device using ACL's
Any other ideas ?
Thanks in advance !
8 Replies 8
Mark Malone
Hi just out of interest if you dont mind me asking why would you use only 1 vrf for multiple customers , no matter how small there sites are im sure they would not want there traffic mixing with another company ? it would be just as quick to create a vrf for each as to appply acls to the CE interfaces.Even though acls will prevent them speaking to each other at ip layer there still in the same FIB table which would be a security concern usually for sensitive traffic
Hi Mark ,
Thanks for the reply , the reason is because I am talking about 1000 plus customers . So i thought it would be easier using the same VRF through the core up to a single firewall.
Having 1000 vrfs would mean a lot of additional configuration and Vlans , IP addressing etc .
Would a firewall cope with this many VLANS /subinterfaces also ? As they would need access blocking at this level if they came up the same single pyhscial connection
So I am trying to think of other ways of doing it  that would block access .
I understand that blocking the subnets onneach CE would only block them at IP level and the other security concerns ,
I am trying to acheive this with a cost effective solution .
What is that firewall for? It controls your customers internet access or controls the access to some specific servers or ....
If it is for internet access or server access, you can create a Firewall VRF and put the firewall interface in that VRF. Then you are able to control all customers based on their IPs. You just need to configure one subnet of IP between firewall and router.
in Firewall VRF, you need to imports RT of all customers, so all the customer routes sit in that VRF.
In customer side, you just need to import RT of Firewall VRF for each customer.
Customer 1
route-target  import 500:500 [for Firewall VRF]
route-target export 100:100
route-target  import 100:100
Customer 2
route-target export 200:200
route-target  import 200:200
Firewall VRF
route-target export 500:500
I hope I understood you question correctly,
Masoud
Hi Masoud
Yes that is what I am trying to do , I willl need use a VRF per customer and leak the routes to the firewall VRF , this would be the default route . I will also have another exit route for Proxy devices to a proxy server and to a filtering platform . I will create another VRF for this a leak the routes again inot this and vice versa using the route targets as you have described above
Thanks a lot
You are most welcome. I have done it before. It worked for me.
devils_advocate
Level 11
Level 11
Presumably none of your 1000 customers use the same IP ranges?
No I will be assigning them
Everybody within the same VRF is just like having no VRF so yes in effect you are limited to acls.
You could use a firewall but you have so many customers you would very probably not have enough interfaces to terminate each customers traffic.
Whether to use acls or not depends on your security requirements.
Jon
