Blocking SSH connection from outside WAN on my router
kkragelund
Hello all from Denmark :)
I want to block ssh on my wan port, so that no one can access my router from the outside.
Everybody says that make an access-list and apply on the vty lines. But i think i found a good way to block it without making access-list in the vty line.
I did
ip access-list extended DENIED_SSH_ACCESS
 deny   tcp any host MY_INTERNAL_IP eq 22
 permit ip any any
And then apply it, on my wan interface
interface fastethernet 4
ip access-group DENIED_SSH_ACCESS in
If i use my port scanner. Port 22 wont show as open wich i think its good think to protect my network. But if i make a access-list in the vty lines allowing only my local network to access and deny everything else, my port scanner vill show port 22 as open. I have used my 4g internet connection from my iphone to test this and it works.
Is there any problem using my methode, instead of using access-list in the vty lines?
Hope you understand my question, my writing skills in english sucks abit and i am training for my CCNA routing and switching certification ! :)
Reza Sharifi
Your writing skill is very good and your question is clear.  You have taken the correct approach by applying the access-list to the link that connects to your provider (your WAN link), so no one can access your network from outside.  It is probably a good idea to block telnet as well
deny   tcp any host MY_INTERNAL_IP eq 23
6 Replies 6
Reza Sharifi
Thank you for your reply Reza Sharifi ! :)
I was wondering if i should add some more roles to the acl, Like denying private addresses from accessing my wan interface?
Maybe you got som tips for wan acls? :)
Yes, here is good link an how to protect yourself from the Internet.
http://www.team-cymru.org/ReadingRoom/Templates/secure-bgp-template.html
Hi, my friend
How you are not apply you access-list on the virtual interface?? like this for example:
interface vty 0 4
ip access-class xx in.
vmf76
I needed to get rid of brutforcing on my WAN and I applied this way:
IP access-list extended SSH-ACCESS
permit tcp host MY-SECOND-ISP-IP any eq 22
line vty 0 4
transport input ssh
access-class SSH-ACCESS in
So, I didn't apply anything on interface F4 and my problem is solved - only me from my second public IP can SSH.
Hello
Just like to add for completeness - You could also append a management plane policer to accomplish a similar thing by stating a specific internal/external interface for mgt access and allowing just the protocol you wish it to be used for?
conf t
control-plane host
management-interface x/x allow ?
Kind Regards
Paul
