Bonded ADSL - Lots of CRC and header errors
anthonyfear
Hi All
Getting intermittent failures using a 1760 router with 2 adsl wics.
Looks to me line like one of the lines has a noise problem? Perhaps someone could confirm this for me?
sh dsl int atm 0/0
ATM0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0xB5
Capacity Used: 34% 93%
Noise Margin: 11.5 dB 5.0 dB
Output Power: 20.0 dBm 10.5 dBm
Attenuation: 62.0 dB 30.5 dB
Defect Status: None None
Last Fail Code: Handshake or init message invalid or had bad CRC
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 1370 (0 spurious)
PHY Access Err: 0
Activations: 6
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 0 576 0 160
Cells: 0 3378 0 593597
Reed-Solomon EC: 0 0 28 31
CRC Errors: 0 2394 27 2183
Header Errors: 0 1235 39 517
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
and ADSL 1/0
router#show dsl int atm 1/0
ATM1/0
Capacity Used: 99% 61%
Noise Margin: 4.0 dB 21.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 20.0 dB 10.0 dB
Last Fail Code: None
Subfunction: 0x15
Interrupts: 2658 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Speed (kbps): 6848 0 448 0
Cells: 50919 0 2505436 0
Reed-Solomon EC: 346 0 0 0
CRC Errors: 4 0 0 0
Header Errors: 3 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
Any ideas? Perhaps a filter problem?
Anthony
0 Replies 0
