Bonding T1s via Cisco Router
cbvisser1
If I implement a Cisco 2600 series router with two T1 cards, am I able to bond the two T1 circuits together to double my total speed?
John Blakley
You can bond the two cards if you have two separate circuits from the same provider coming into the building. The provider will give you an address, and you use this address on a multilink interface. The multilink interface is assigned a group, and your two T1 cards are assigned to use the multilink group.
HTH,
John
HTH, John *** Please rate all useful posts ***
Rick Morris
Level 6
Level 6
You can do this and it is quite easy to do. However you must have the ISP do this as well. Here is a link I found that may help:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfgt1.html#wp1192082
Not specific for your router but the info is still the same.
Here is a sample config too:
interface Multilink1
bandwidth 3072
ip address
ip access-group Multilink1_in in
no keepalive
no cdp enable
ppp chap hostname
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
interface Serial0/0/0
description
bandwidth 1536
no ip address
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
load-interval 30
fair-queue
no cdp enable
ppp chap hostname
ppp multilink
max-reserved-bandwidth 100
interface Serial0/1/0
bandwidth 1536
no ip address
ip flow ingress
ip nat outside
encapsulation ppp
no ip mroute-cache
load-interval 30
fair-queue
no cdp enable
ppp chap hostname
ppp multilink
ip route 0.0.0.0 0.0.0.0
cbvisser1
Now is it just two T1 cards or can you do more than two if you have open slots for more card
You can combine upto 10 T1's to create a Multilink PPP bundle over serial connection
Masood Rana
