Boot problems
rsynyuk99
Hi everybody!
I have a problems with Cisco 2621. It unable to start IOS. After IOS image decompression it hangs without any messages. But if I press Enter key, strange message displayed:
Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x431e50
Self decompressing the image : #################################################
########################################## [OK]
*** Unexpected Console FIFO timeout interrupt ***
PC = 0xfff24d90, Vector = 0x500, SP = 0x800049f4
I have no problems with ROMMON and upgrading IOS image via tftpdnld. I tried to use different IOS images, but without success.
weird indeed, I cannot find any information about that error either. I assume you have verified that you have sufficient flash and DRAM for the IOS you are trying to load ?
I wonder if the error has anything to do with you hitting , are you using Hyperterminal ? If so, you might want to try and upgrade to version 6.3:
HyperTerminal Private Edition version 6.3
http://www.hilgraeve.com/htpe/index.html
Of course there is always a chance that you have a hardware problem (bad flash or DRAM memory, bad memory slot, etc.). Are you in a psoition to exchange the flash and/or DRAM memory and see if that makes a difference ?
GP
