Boot variable cisco 3845
victor_87
Hi all,
this command was executed on a cisco 6500 and i got the output
6500#sh boot
BOOT variable = disk0:s72033-advipservicesk9_wan-mz.122-18.SXF6.bin,1;sup-bootflash:s72033-pk9sv-mz.122-17d.SXB10.bin,1;
CONFIG_FILE variable =,
How can i get the same result on a Cisco 3845. I need to see what the boot variable is set to, Show boot command does not work.
paolo bevilacqua
There is no command to show that.
You have to examine the config file for boot commands.
Leo Laohoo
Paolo's right. The sh boot is only valid for switches and ASA (I think). For routers, you have to look at the "boot-start-marker" section. If no entry then the appliance will boot the first .bin image from the top.
Hope this helps.
Joseph W. Doherty
As the others have noted, there isn't an explicit command for a router, however if boot infomation is in the config file, you might try:
show config (or run) | include boot
