Booting into Router 1
Sadies500
I have configured two routers, Router 1 and 2 but after configuring router 2 i am unable to get back into router one configuration? Everytime i restart (im using TeraTerm) teraterm and re-boot the routers the command line automatically logs into Router 2...how do i change back to router 1?
Richard Burts
Mandy
We do not have quite enough information here to give good answers to your question. If you are using Tera Term then the first question is whether TeraTerm is using a telnet/SSH connection or is using a serial (console) connection.
And if it is using a serial(console) connection then what is the physical connection of the PC? Are you connected to a console post of the router or are you connected to a terminal server which is then connected to the router serial ports?
Help us understand this and we might be able to give you better answers.
Rick
Rick
Hi it is using a serial connection, and connected via the console port of the router i have two routers connected that way with a serial lead between the two of them.
Sorry so yes it is connected via a console connection and not telnet...
