bus error at PC 0x23B1DEEC, address 0x3C
Piotr Pawlowski
Dear all,
Today I faced two bus errors on my cisco 2911 router. Of course, after it occurs, router rebooted. Below is a detailed information about second one:
System returned to ROM by bus error at PC 0x23B1DEEC, address 0x3C at 09:06:47 UTC Tue Apr 9 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T.bin"Last reload type: Normal ReloadLast reload reason: bus error at PC 0x23B1DEEC, address 0x3C
Stack trace from system failure:
FP: 0x31143F08, RA: 0x23B1DEEC
FP: 0x31143F38, RA: 0x23B28910 FP: 0x31143F90, RA: 0x23B2F9CC FP: 0x31143FA8, RA: 0x22EB343C FP: 0x31143FF0, RA: 0x22EB5AE0 FP: 0x31144018, RA: 0x22E9A31C FP: 0x31144078, RA: 0x22E9A55C FP: 0x311440B0, RA: 0x22E9A63C
Just before bus error, I had following error message in console:
*Apr  9 09:06:44.611: %SYS-2-NOBLOCK: may_suspend with blocking disabled. -Process= "Ethernet Msec Timer CFM", ipl= 0, pid= 119
-Traceback= 23C7D6F8z 21296A50z 23C3A8E8z 23C3A8CCz *Apr  9 09:06:44.631: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1: the fragment table has reached its maximum threshold 16 *Apr  9 09:06:45.623: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Ethernet Msec Timer CFM", ipl= 0, pid= 119
I will add, that I had IPSLA configured on ga0/1 and ga0/2 , on ga0/0 I have NAT.
I suspect bad IPSLA configuration, but I a, walking in the fog right now.
Thank you in advance for any help, tip or support.
Piotr
Piotr Pawlowski
Yesterday my router crashed again, now with different error:
Last reload reason: bus error at PC 0x230FAF2C, address 0xB0D0B11
Those errors stop me in applying router in production enrironment. Does anybody know what is the cause of such strange behaviour?
Thank you in advance for help.
Already answered in the ccie.pl thread here:
http://ccie.pl/viewtopic.php?p=129578#129578
