SFP-T not comming up on 100 full
fernandezj
I try to connect 3750X (15.0.1(SE3)) with PC or router  that is interface card is fixed to 100Full..
on 3750X-12S-E I plug a SFP-T, this SFP is ok:
show int capa:
GigabitEthernet1/0/12
  Model:                 WS-C3750X-12S
  Type:                  10/100/1000BaseTX SFP
  Speed:                 10,100,1000,auto
  Duplex:                half,full,auto
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
But with Speed and duplex fixed the interface is up arround 1-4s and move to down and errer-disable...
If you have a idea...
Best regards
Steven Clinton
Who makes the SFP and what is the model number?
the model number is SFP-T (GLC-T) and the configuration is simple:
int g1/0/12
speed 100
duplex Full
Best regards
