BOOTLDR
ptsomokos
Does anyone knows why i'm getting this output from a 836 Cisco?
rommon 1 > boot c836-k9o3y6-mz.123-14.T7.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "c836-k9o3y6-mz.123-14.T7.bin"
rommon 2 >
It refused to load from flash.
I make the whole tftpdnld procedure with 3 different ios
Check this out also
(i'm givving) rommon 2 > boot flash:c836-k9o3y6-mz.123-14.T7.bin
(and getting) Checksum failed on c836-k9o3y6-mz.123-14.T7.bin
Expected checksum: f411, calculated checksum: a28b
open: file "c836-k9o3y6-mz.123-14.T7.bin" not found
open(): Open Error = -1
boot: cannot load "flash:c836-k9o3y6-mz.123-14.T7.bin"
Notes: The image its loaded propriate in the flash with the correct file size on it
htarra
Level 4
Level 4
type this in your Cisco 836 ADSL :
rommon >boot flash: c836-k9o3y6-mz.123-14.T7.bin
rommon >reload
Then you're going to be in a normal mode,
in this point, please type:
#config t
(config)#no boot system
(config)#boot system flash: c836-k9o3y6-mz.123-14.T7.bin
(config)exit
#copy run start
#sh ver
Here just check at the end if the configuration register is Ox2102
if not just type:
#config t
(config)#config-register 0x2102
(config)#exit
#copy run start
At the end restart the Cisco 836 ADSL :
#reload
He can't enter any of the IOS commands you're suggesting, precisely because the router fails to boot IOS.
Thanks for your answer.
The problem was slightly different.
I tried 3 IOS and while the flash was 12MB probably was too mush for it.
Thats why the screens I posted
I tried the first one 7.5MB with xmodem and everything goes fine.
The initial problem was that someone probably delete the ios and the router fell on rommon mode
Goutam Sanyal
Level 4
Level 4
With the addition with Paolo, I'd like to suggest you to tri with "boot slot0:". If till you are facing the same problem, try to upload the IOS via Xmodem.
Goutam
Pls rate if it helps u!!!
