Bootloop on Router 2611XM
Diogo Buhler
Hello guys, I'm trying to start one cisco router, but the boot is always in loop, cause of some error.
I cant stop the boot in order to clear the config files, or even acess the cli.
The output is below:
program load complete, entry point: 0x80008000, size: 0x144f484
Self decompressing the image : #################################################
   #################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
00036B          0X00103980 C2611XM Dual Fast Ethernet
0002A0          0X0003C864 Virtual Private Network (VPN) Module
                0X00098670 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X003E9854
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 4 percent iomem. [4Mb/96Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-JK9O3S-M), Version 12.3(24), RELEASE SOFTWARE (fc   4)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 18-Oct-07 14:27 by stshen
Image text-base: 0x80008098, data-base: 0x820038F4
00:00:30 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 100, PC = 81DA47   68
-Traceback= 81DA4768 81DA5B50 8020AE50 8020BCA0 803F73D8 8030DDC0 8030DFCC 803FE   9DC 804020DC
Free space check for flash:crashinfo_19930301-000030 failed (68/646)
=== Flushing messages (00:00:30 UTC Mon Mar 1 1993) ===
Queued messages:
*Mar  1 00:00:30.381: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console d   ebugging output.
*Mar  1 00:00:06.206: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0   , changed state to up
*** System received a SegV exception ***
signal= 0xb, code= 0x100, context= 0x833f1d98
PC = 0x81da4768, Vector = 0x100, SP = 0x835ff798
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 98304 Kbytes of main memory
Self decompressing the image : #####################################################################################################
Can anyone help me solve this issue?
5 Replies 5
Peter Paluch
Hi Diogo,
This does not look good. Segmentation violation are caused either by grave software errors or by hardware fault, most commonly, RAM issues.
I would suggest using a different IOS image with a lower feature set that consumes less memory. If that IOS boots up, there is a good chance that just the IOS image you originally had at the router is corrupt, tried to use too much memory, or has some issues. If the problem persists, you may still try pulling out all WICs and NM modules out of the router, leaving just the barebone router to boot up. If nothing helps, I am afraid the only option left is to try replacing the DRAM modules.
Best regards,
Peter
Well, I tried it.
I managed to enter in rommon and using XModem uploaded the ios:
c2600-ik9o3s3-mz.123-22.bin
But the problem persists :X
New update:I loaded a new IOS:
c2600-i-mz.123-22.bin
and It worked
The issue now is, will the funcionalities work with this ios, like vpn and so?
If not, what IOS you advice me to put?
Thanks in advance.
Hello Diogo,
You have put an IOS with the basic IP feature set. I am almost sure that VPN will not work with this IOS.
Can you post the output of show version command here? In order to help you, I need to know the amount of your DRAM and FLASH.
Best regards,
Peter
Peter thanks for the great help.
Atm, It will stay like this, with the most simple firmware, latter I might try another firmware, but atm, I've the router in the museum (joking)
Anyway, thanks for the help
