Changing system mtu size
r.luby
I have 2 Cisco 3750X in a stack and i want to change mtu size from 9000 to 1500
ISCSI-SWITCH(config)#system mtu jumbo 1500
Changes to the system jumbo MTU will not take effect until the next reload is done
    ISCSI-SWITCH#copy run start
    Destination filename [startup-config]?
    Building configuration...
    [OK]
Do I have to reboot the whole stack at once or can i reboot a single slot using:
ISCSI-SWITCH#reload slot switch_member_number
so that I can use my redundency because I can not down with with servers
John Blakley
You'll have to reload the whole stack...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I had hoped for a favorable response ;-) but thanks for your comment.
