Bought an old Cisco ISR4451-X-VSEC/K9. How to factory reset?
varunoberoi
I have tried
>write erase
>reload
It resets the router, but the start up configuration prompt doesn't come. I need it to come. What command should I run?
The router runs Cisco IOS 15.5
Leo Laohoo
Console into the router and reboot the router.
Post the entire bootup process.
NOTE:  Do not post screenshots.
balaji.bandi
check below guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/xe-16-12/isr4400swcfg-xe-16-12-book/m_perform_factory_reset_isr.html.
I have also follow my guide it works :
https://www.balajibandi.com/?p=1420
still, issue post complete console output for us to understand what was the issue.
BB
Leo Laohoo
on a side note, is the setup facility available ?
ISR4451#setup <ENTER>
