BPDU GUARD/ FILTER
sukesh tandon
Why do we need BDPU GUARD and BPDU FILTER both.? I think both are used to protect switch loops ensuring that the port transitions to forwarding state quickly.
Can anyone help me on this.
Sukesh Tandon
6 Replies 6
Philip D'Ath
You may have one of the other configured but not both at the same time on the same port.
bpduguard is used when connecting devices that should not be generating spanning tree packets, such as workstations, servers, etc.
bpdu filter is used when you are connecting a trunk port to another device (often a service provider) and you want want to exchange spanning tree with them, and you are 100% confident that no loop can be formed.
Hello
Here is a summary of some testing I did regards those stp features a while back.
portfast (global or interface) = bypasses listen/learn goes into forwarding state
bpduguard
(Global)  - goes through stp process - no blocking
(Interface) - listen state then blocks port (err-disable}
bpduguard + portfast (any variation) = jumps to forwarding from blocking - then blocks port (err-disable
Bpdufilter (global or interface) = goes through stp process (no filtering occurs)
Bpdufilter (Global) + Portfast = jumps to forwarding from blocking (no filtering occurs)
Bpdufilter (interface mode) + Portfast - jumps to forwarding from blocking (filtering occurs)
res
Paul
Kind Regards
Paul
Hi Paul,
Can we discuss some of your findings? I know them differently - perhaps I am in error so it's always good to share and discuss our experiences.
True. It should be noted that the spanning-tree portfast default command in the global configuration mode applies only to ports operating as access ports. It ignores ports operating as trunk ports.
bpduguard
To my knowledge, this is different. BPDU Guard configured globally applies only to PortFast-enabled ports, that is why the global configuration level command actually says
spanning-tree portfast bpduguard default
In this case, non-PortFast-enabled ports won't be protected by this global BPDU Guard. PortFast port will of course jump into Designated Forwarding role/state as soon as they come up (because they're PortFast-enabled), and should they ever receive a BPDU, they will get err-disabled thanks to the BPDU Guard. Ports that are not PortFast-enabled won't be affected by this global BPDU Guard because it does not apply to them.
bpduguard
This depends on whether the port is PortFast-enabled. If it is PortFast-enabled then it jumps right into Designated Forwarding. If it is not (in that case, the BPDU Guard had to be configured directly on the interface, otherwise it wouldn't apply), then correctly, the port will start in the Listening state.
To my knowledge, this is different. BPDU Filter configured globally applies only to PortFast-enabled ports, that's why the command says:
spanning-tree portfast bpdufilter default
BPDU Filter configured globally causes each PortFast-enabled port to send only 11 BPDUs (over 10 Hello intervals) and then it stops sending BPDUs through that port. If the port receives a BPDU at any time (during those 11 BPDUs or afterwards), both PortFast and BPDU Filter will be deactivated on that port, and the port will start operating as a normal non-edge unfiltered port. Hence, BPDU Filter configured globally performs outbound filtering (after a while) but does not perform inbound filtering.
BPDU Filter configured on an interface operates differently and much more strictly - it prevents sending and receiving BPDUs whatsoever.
True - but the port will send only 11 BPDUs and then stop sending them, so outbound filtering will actually kick in after 10 BPDU Hello periods.
True. All BPDUs, incoming and outgoing, are unconditionally filtered.
Best regards,
Peter
Hello Peter
one inportant thing I  forgot to mention was my testing was based on the attachment of a rouge switch of a non trunk interface and the port receiving unwarranted bpdus
res
paul
Kind Regards
Paul
Hi Paul,
Well, depending on the timing, this could have skewed your experiment results.
The main problem is the PortFast setting on a port that influences whether the globally configured BPDU Guard and BPDU Filter apply to that port.
PortFast is a feature that has an administrative state, and an operational state. The administrative state simply refers to whether the PortFast is configured for a port - either on the port directly, or in the global configuration, in both cases assuming that the port is operating in access mode. This administrative state alone does not mean, however, that the port truly acts as a PortFast-enabled port. It only means that the switch will attempt to treat that port as an edge port, but if it detects another switch by receiving a BPDU, it will forget about the PortFast and will start treating the port as a non-edge port - and the true status of the PortFast on a port is the operational state.
A port configured with PortFast always comes up as a PortFast-enabled port, meaning that the operational state of the PortFast on that port is "enabled". However, when such a port receives a BPDU, the operational state of the PortFast on that port is moved to "disabled" even though the port remains configured as PortFast port - but it no longer acts as a PortFast-enabled port, rather, it is a normal, non-edge port.
What I am saying is that you might have configured a port as a PortFast port, but until you configured the BPDU Guard or BPDU Filter in the global mode, the port already received a BPDU and stopped being a PortFast-enabled port, and as a result, the globally configured BPDU Guard/Filter no longer applied to it.
It's all just a hunch, though... After you go over my explanations of the features in my previous post, would you say they match your observations?
Best regards,
Peter
Hello Peter
Apologies for the late reply - Work commitments and all!
Here is the complete itinerary of the testing that I recorded - what I posted previous was a summary and may have been misleading;
I think it support what you have stated.
Tested in PVST mode:
portfast-
global or interface - bypasses listen/learn goes into forwarding state
Bpduguard-
spanning-tree portfast bpduguard (Global)  - goes through stp process - no blocking
spanning-tree bpduguard enable (Interface) - listen state then blocks port (err-disable}
spanning-tree portfast bpduguard default -jumps to forwarding from blocking - then blocks port (err-disable}
spanning-tree bpduguard enable (interface mode) -jumps to forwarding from blocking - then blocks port (err-disable}
spanning-tree portfast – (interface mode) -jumps to forwarding from blocking -  -then blocks port (err-disable}
spanning-tree portfast–interface mode)
spanning-tree bpduguard enable -(interface mode) jumps to forwarding from blocking -  -then blocks port (err-disable}
Bpdufilter
spanning-tree portfast bpdufilter default (Global) -listening/learning/forwarding (rouge switch becomes root no filtering occurs)
spanning-tree bpdufilter enable (interface mode) -listening/learning/forwarding (rouge switch becomes root no filtering occurs)
spanning-tree portfast bpdufilter default- jumps to forwarding from blocking (rouge switch becomes root no filtering occurs)
spanning-tree portfast – (interface mode) -jumps to forwarding from blocking (rouge switch becomes root no filtering occurs)
spanning-tree bpdufilter enable – (interface mode) jumps to forwarding from blocking ( keeps root status – so looks like bpdu’s are filtered)
spanning-tree bpdufilter enable– (interface mode) jumps to forwarding from blocking ( keeps root status – so looks like bpdu’s are filtered)
Tested in RSTP mode:
Portfast-
Default 802.1w standard (global) -  tranmists 2x proposals goes into Fwd state
per interface   ---         initializes port goes straight to fwd state
Bpduguard-
Portfast  - Default 802.1w standard (global)
spanning-tree portfast bpduguard default (Global)  -  tranmists 2x proposals goes into Fwd state - no blocking
spanning-tree bpduguard enable (Interface) -tranmists 2x proposals  then blocks port (err-disable}
spanning-tree portfast (interface)
spanning-tree portfast bpduguard default (Global -  initializes port then blocks port (err-disable}
Bpdufilter
spanning-tree portfast bpdufilter default (Global)  tranmists 2x proposals goes into Fwd state - no blocking (rouge switch becomes root no filtering occurs)
spanning-tree bpdufilter enable (interface mode) -initializes port goes straight to fwd state  (so looks like bpdu’s are filtered)
spanning-tree portfast bpdufilter enable-  initializes port goes straight to fwd state (so looks like bpdu’s are filtered)
res
Paul
Kind Regards
Paul
