bri line is unable to dial on cisco 1841 router when i configure mlppp
jvr_infotech
Dear all,
i have a cisco 1841 router and i installed 2 bri module in it and configured that router my NT box is unable to dail automatically . when i keep phone instrumnets to NT box and dail a number its port is coming to active and when i test a call then the 2 b-channels is coming up and same with the other port also....
please help me any one who implemented this...i am giving my configuration.
THIS IS MY 1841 END ROUTER CONFIGURATION
CISCO#sh run
Building configuration...
hostname CISCO
ip domain name yourdomain.com
ip multicast-routing
isdn switch-type basic-5ess
interface FastEthernet0/0
ip address 192.168.8.49 255.255.255.0
ip accounting output-packets
ip pim dense-mode
ip igmp join-group 239.0.0.1
speed auto
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
ip directed-broadcast
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn point-to-point-setup
interface BRI0/1/0
no ip address
encapsulation ppp
dialer-group 1
interface Dialer1
ip unnumbered FastEthernet0/0
ip access-group dialer_in in
ip access-group dialer_out out
ip pim dense-mode
encapsulation ppp
dialer in-band
dialer string 66682540
dialer load-threshold 1 either
dialer-group 1
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended dialer_in
permit tcp any any syn log-input
permit ip any any
ip access-list extended dialer_out
permit tcp any any eq www
permit tcp any any eq 443
permit udp any any
permit icmp any any
permit tcp any host 192.168.25.2
permit tcp any host 192.168.25.3
permit tcp any host 192.168.25.110
permit tcp any host 192.168.25.101
permit tcp any host 192.168.25.21
deny tcp any any eq 445
permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
password CISCO123
login
transport input telnet
line vty 5 15
privilege level 15
login local
THIS IS MY PRI ROUTER CONFIGURATION
interface Dialer131
ip access-group in_traffic in
ip access-group out_traffic out
ip pim dense-mode
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer idle-timeout 3600 either
dialer caller 4066470717
dialer caller 4066451127
peer default ip address dhcp-pool local-branches
ppp multilink
PLEASE GIVE ME SOLUTION WHERE I DID WRONG IN THIS CONFIGURATION...
IN ADVANCE THANKS
6 Replies 6
smothuku
Level 7
Level 7
Hi JVR ,
I think you missed out dialer-group command on pri router.
Configure dialer-group under int dia 131.
satish
Hi ,
there is no need of dailer-group in pri int.becoz some single bri lines are working on same confgiration.my main problem is why that router or NT Box automatically not dailing .
NO b channel basically means you have no channel to dial out as your simulator is set up incorrectly or your switch type is wrong.
what does "sh isdn status" show ? are you sure your really 5ess ? and not NI1 ?
Thx
shillyar
Verify your dialing numbers are correct as one of them looks kinda strange being 8 digits long. Also turn on chap/pap authentication.
Also what are your spid # ?
turn on debug dialer, debug isdn q931.
Thx Steve
Hi Shillyar,
that number is just i given for description,and next i turned on q931, then i found a error NO B-channel Found
shillyar
try also doing a ping verses a test call as I have see calls flaged incorrectly with the 2 commands.
Thx
