Bridge configuration at ISR 4000
WilmerAndrango
Hi.
I´m configuring a new router ISR 4000, but i cannot find all needed commands for bridge feature.
Please your help if somebody know the equivalent commands for ISR 4000 series.
Thanks in advance.
Step by Step Bridge Group Virtual Interface (BVI) Configuration
Integrated Routing and Bridging configuration on Router1:
Router (config)#int fa0/0
Router (config-if)#bridge-group 1                           NOT SUPPORTED
Router (config-if)#no shut
Router(config-if)#exit
Router (config)#
Router (config-if)#int fa1/0
Router(config-if)#bridge-group 1                           NOT SUPPORTED
Router(config)#
Create Bridge Group Virtual Interface (BVI) and configure the IP and Routing credentials.
Router1(config)#bridge irb
Router (config)#int bvi1
Router(config-if)#ip add 192.168.2.1 255.255.255.0
Router(config)#bridge 1 protocol ieee                                             NOT SUPPORTED "ieee"
Router (config)#bridge 1 route ip
Router(config)#
7 Replies 7
marcusauman
Here is the equivalent.
interface Gig0/0/1
   service instance 25 ethernet
     encapsulation dot1q 25
     rewrite ingress tag pop 1 symmetric
     bridge-domain 25
interface Gig0/0/2
     bridge-domain 25
interface BDI25
   ip address X.X.X.X 255.255.255.0
   no shut
Since you don't mention Spanning-tree protocol in this syntax (vs. bridge X protocol ieee), is it a given?  Or.....do you specify spanning-tree protocol somewhere else?
My4321-cir1(config)#bridge 1 protocol ?
  dec          DEC protocol
  ibm          IBM protocol
  vlan-bridge  vlan-bridge protocol
See how this doesn't give me ieee protocol option?  Please explain.
Did anyone ever address this issue?
Looking to setup STP on the ISR 4000.
No one answered, but I was able to piece it together.
That's awesome news!  How did you get STP on the ISR 4000 with one port forwarding and one port blocking?  I'm attempting to address this myself.  Would appreciate learning the steps you took.  Or if you could share sample configs?
Here is the basic config that I was originally looking for.  This is how you essentially create Sub-Interfaces on a single physical interface and how you accommodate the dot1q tag.
bridge-domain 100
bridge-domain 200
bridge-domain 900
interface GigabitEthernet0/0/0
 description Sample Sub-IFs w/Dot1q
 no ip address
 no ip redirects
 no ip proxy-arp
 negotiation auto
 service instance 100 ethernet
  description Vlan100
  encapsulation dot1q 100
  bridge-domain 100
 service instance 200 ethernet
  description Vlan200
  encapsulation dot1q 200
  bridge-domain 200
 service instance 900 ethernet
  description Vlan900
  encapsulation dot1q 900
  bridge-domain 900
interface BDI100
 description Vlan100 - L3
 ip address XX.XX.XX.XX XX.XX.XX.XX
 no ip redirects
 no ip proxy-arp
 ip pim sparse-mode
 ip tcp adjust-mss 1360
interface BDI200
 description Vlan200 - L3
 ip address 172.28.XX.XX 255.255.XX.XX
 no ip redirects
 no ip proxy-arp
 ip pim sparse-mode
interface BDI900
 description Vlan900 - L3
 no ip redirects
 no ip proxy-arp
Hello, excuse me, support QoS ( policy IN , OUT ) in services instances?  CIR ,MIR?.
regards
